Thread: AC trouble
Results 1 to 11 of 11
  1. #1 Re: AC trouble
    Michigan
    I have seen them in stores. Is there any issues with the vacuum being diminished? Also, as stated in my 1st message, I would think jumping the switch would be the easiest, but the switch has 3 wires on it. Do you know which to jumper? I don't have the factory manual and I can't find the diagram to show which pin is which.
  2. #2 Re: AC trouble
    Michigan
    Well, I did the charge myself, for good or bad. I got a recharge can with the gauge, connected it and pumped the button a few times, then the compressor clicked on. After emptying the can in the system, it only got up to about 35psi. It is a little cooler here in MI today, so maybe that is all it will get. It did feel like cooler air was coming out. We'll see when we get another hot day.
    For those that have used the cans of refridgerant, does this sound normal? Should I get a 2nd can? Did I just completely screw up my system?
    Thanks,
    Scott
  1. Trouble with speakers
    By That Guy in forum Audio, Security & Visual Electronics
    Last Post: 05-11-2009, 07:48 PM
  2. Radiator fan trouble..
    By bowtechguy in forum General Tech Discussion
    Last Post: 04-26-2009, 12:49 PM
  3. S/C Trouble...
    By LaCabra in forum General Tech Discussion
    Last Post: 04-01-2009, 09:45 PM
  4. gtp having trouble idling
    By ibanez0110 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:37 PM
  5. trouble codes
    By BADAZGTP in forum Forum Bugs/Suggestions
    Last Post: 07-26-2008, 10:59 AM
