Thread: Trouble with speakers
Results 1 to 6 of 6
  1. #1 Trouble with speakers
    Colorado
    I have recently started having problems with a whinning sound coming from my front right speaker and sometimes the rear speakers also. When I accelerate the noise pitch gets higher. I tried messing with the wires to the sub and amps but everything seems nice and tight and I only just noticed it recently.
    Does it sound like a connection problem with the amps or something else. I bought the car used and didnt install the system so I honestly dont know much about it. My dad was using the car for about a month before I could pick it up and never noticed the problem and anyone with working ears would notice the sound.
    Any help would be great. Thanks
  2. #2 Re: Trouble with speakers
    SE Level Member bloxmagic's Avatar
    Oct 2008
    Carmel
    it sounds like you are getting feedback from your alternator or the battery. I had a friend who got this in his 97 maxima, to fix it we relocated his ground and checked all the connections because if one connection is bad or a ground is not fully secure it is possible for all types of feedback
  3. #3 Re: Trouble with speakers
    Colorado
    OK, Ill have to get in the back and figure out how he has it wired up and check everything. I figured it was a loose connection somewhere but the whole getting high pitched with the engine threw me off. Thanks!
  4. #4 Re: Trouble with speakers
    Oct 2008
    Carmel
    yea no problem let me know what you find
  5. #5 Re: Trouble with speakers
    GTP Level Member dstout's Avatar
    ky
    Seems I had that problem years ago and I changed the spark plug wires. The ones I changed out were not very good, with better wires the problem went away.
    Try that if nothing else helps.
  6. #6 Re: Trouble with speakers
    Oct 2008
    Carmel
    he has good advice because that is part of the electrical system too...
    '00 Fire Engine Red GT Sedan - PCM Tuned, 180* T-Stat, FWI, 70mm Throttle Body Adapted, MSD Coil Packs, MSD Ignition Wires, AL 605 Plugs, Coated Headers (New Headers Soon), 145 amp high output alternator, 2 12" Kenwood Subs, Alpine PDX1.1000 , Alpine Type R Speakers, Alpine HeadUnit
  1. got some trouble codes
    Last Post: 04-10-2009, 10:44 PM
  2. S/C Trouble...
    By LaCabra in forum General Tech Discussion
    Last Post: 04-01-2009, 09:45 PM
  3. 92 grandprix trouble
    By GAbriel in forum General Tech Discussion
    Last Post: 03-17-2009, 01:55 PM
  4. trouble codes
    By BADAZGTP in forum Forum Bugs/Suggestions
    Last Post: 07-26-2008, 10:59 AM
  5. Trans trouble
    By landst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-20-2008, 10:52 PM
