Thread: $750 to spend what are the must do mods??
Results 1 to 20 of 39
Enjoijoe $750 to spend what are the... 06-18-2009, 10:12 PM
superv6 Re: $750 to spend what are... 06-18-2009, 11:44 PM
gotboost3 Re: $750 to spend what are... 06-19-2009, 12:18 AM
FuglyGTP Re: $750 to spend what are... 06-19-2009, 12:33 AM
GTP Ryan Re: $750 to spend what are... 06-19-2009, 12:50 AM
Bio248 Re: $750 to spend what are... 06-19-2009, 08:09 AM
carl06GT Re: $750 to spend what are... 06-19-2009, 09:59 AM
minichopper6hp Re: $750 to spend what are... 06-19-2009, 11:20 AM
Enjoijoe Re: $750 to spend what are... 06-19-2009, 12:18 PM
Enjoijoe Re: $750 to spend what are... 06-19-2009, 12:56 PM
mickey t Re: $750 to spend what are... 06-19-2009, 01:02 PM
Enjoijoe Re: $750 to spend what are... 06-19-2009, 02:13 PM
mickey t Re: $750 to spend what are... 06-19-2009, 02:27 PM
Enjoijoe Re: $750 to spend what are... 06-19-2009, 02:44 PM
mickey t Re: $750 to spend what are... 06-19-2009, 03:25 PM
Enjoijoe Re: $750 to spend what are... 06-19-2009, 03:45 PM
blueguy Re: $750 to spend what are... 06-19-2009, 03:46 PM
mickey t Re: $750 to spend what are... 06-19-2009, 03:59 PM
blueguy Re: $750 to spend what are... 06-19-2009, 04:19 PM
Enjoijoe Re: $750 to spend what are... 06-20-2009, 11:17 PM
Enjoijoe Re: $750 to spend what are... 06-20-2009, 11:56 PM
blueguy Re: $750 to spend what are... 06-21-2009, 12:29 AM
Enjoijoe Re: $750 to spend what are... 06-21-2009, 01:17 AM
blueguy Re: $750 to spend what are... 06-21-2009, 02:53 AM
mickey t Re: $750 to spend what are... 06-21-2009, 03:38 AM
Enjoijoe Re: $750 to spend what are... 06-21-2009, 12:35 PM
minichopper6hp Re: $750 to spend what are... 06-21-2009, 12:35 PM
Enjoijoe Re: $750 to spend what are... 06-21-2009, 12:40 PM
Enjoijoe Re: $750 to spend what are... 06-21-2009, 01:39 PM
blueguy Re: $750 to spend what are... 06-21-2009, 01:49 PM
Bio248 Re: $750 to spend what are... 06-21-2009, 03:25 PM
Enjoijoe Re: $750 to spend what are... 06-21-2009, 04:58 PM
Bio248 Re: $750 to spend what are... 06-21-2009, 08:24 PM
Enjoijoe Re: $750 to spend what are... 06-21-2009, 08:56 PM
blueguy Re: $750 to spend what are... 06-21-2009, 09:01 PM
blowfishRus6 Re: $750 to spend what are... 06-22-2009, 11:14 AM
Enjoijoe Re: $750 to spend what are... 06-22-2009, 03:52 PM
TheOtherNick Re: $750 to spend what are... 06-22-2009, 06:17 PM
blowfishRus6 Re: $750 to spend what are... 06-23-2009, 01:36 AM
  1. #1 $750 to spend what are the must do mods??
    Weymouth, MA
    Just wondering what the must do mods are
  2. #2 Re: $750 to spend what are the must do mods??
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Do u have a gtp or a gt? Honestly if u can buy used stuff. I check on craigslist regularly and a lot of guys on here are sellin their parts for cheap. I would start with the basics like 180 tstat for $10, make ur own fender well intake for $50 tops with spare tubing or going to ace hardware for pcv tube. Then I say exhaust. Go with a better flowing downpipe. That will also get rid of that crappy u-bend before the carback. That helped me a lot. Get an off the shelf pcm. $100 and its worth it. And if u can get a front powerlog. It replaces the stock front manifold. Anyone else?
  3. #3 Re: $750 to spend what are the must do mods??
    Donating Users
    Plainfield, IL
    750$
    -welded pacesetters (50$ to get welded) 450$
    -DIY FWI 50$
    -180 stat 10$
    -colder plugs AL104's 12$
    -press on 3.4 50$
    -good ass tune from a person with a hp tuner 100-150$
    =fun ass DD and money for beer left over....if you have a gtp....if not blow it on a cam
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  4. #4 Re: $750 to spend what are the must do mods??
    Nov 2008
    Chicago
    I've got an SS IC (475 new from another member), ebay intake w/9" k&n ($50), custom exhaust ($340) and will be getting an ecu (100-169) and dropping pulley sizes (price varies, im estimating around 60-135).
    If I where you I'd get the ecu, intake (def a noticeable difference), downpipe/ubend delete (made a big difference)- $120 from zzp, front plog - $120. That's 390 right there. You might be able to drop down to a 3.6 or a 3.5 but definitely scan for KR.
  5. #5 Re: $750 to spend what are the must do mods??
    SE Level Member GTP Ryan's Avatar
    Mass
    im looking for mods to i have around 400$ to spend i know its not alot i have an 04 gtp comp g id like to get a new exhaust but i kno it would cost alot more than 400 for a nice exhaust any cheap mods i can do that would make a noticeable difference and also not void the powertrain warranty
  6. #6 Re: $750 to spend what are the must do mods??
    your first mods should either be an intercooler setup or a cam setup. easy as that.
  7. #7 Re: $750 to spend what are the must do mods??
    Aug 2008
    KCMO
    how much does an IC setup cost?
  8. #8 Re: $750 to spend what are the must do mods??
    Banned - Busted For Scamming
    Feb 2009
    contact TDCRACING, a member here, he has the best and least expensive setup around.
  9. #9 Re: $750 to spend what are the must do mods??
    Weymouth, MA
    What is a good off the shelf pcm to get and what are the benifits of it??? Also whatis a good site to buy these mods off of?
  10. #10 Re: $750 to spend what are the must do mods??
    Weymouth, MA
    i think i will go with a 3.4 pully, CAI, 3"downpipe and a good tune.
  11. #11 Re: $750 to spend what are the must do mods??
    SE Level Member mickey t's Avatar
    Dover, DE
    Jus to save everyone else the trouble... Hold off on the pulley until you get enough air flowing... No a CAI and DP doesnt flow enough air : ) good luck with your mods... If you want a good sounding SC theres a guy on here that does a bomb job for a really fair price...
    The Surgeon General never said anything about smoking the competition
  12. #12 Re: $750 to spend what are the must do mods??
    Weymouth, MA
    Quote Originally Posted by mickey t View Post
    what mods should i do before i go for the pulley
  13. #13 Re: $750 to spend what are the must do mods??
    Dover, DE
    I would say cam, intercooler,headers, CAI/FWI, u-bend delete, rockers, 180tstat, colder plugs w better wires, good tune... thats a good set up for a pretty small pulley... I wouldnt go that low on your DD... you could get by with less... wouldnt reccomend it but it could be done... thrashercharged.com sales a package deal w a few mods...
  14. #14 Re: $750 to spend what are the must do mods??
    Weymouth, MA
    I think I will go with a K&N CAI, 3" downpipe,headers(can someone reccommend me a good pair)and an off the shelf pcm. Also what are rockers and what does a 180tstat do??
    P.S could someone estimate what my 1/4mile time would be with those mods
  15. #15 Re: $750 to spend what are the must do mods??
    Dover, DE
    Im not much for estimating track times... depends on many variables... driver...climate... you get the picture... a 180* thermostat should be one of the very first mods you take into consideration... it will run you no more than 10$ and its exactly what its described as... a lower degree thermostat... I think stock is 195* but dont quote me on that... If you buy a K&N intake your jus wasting your money... I did it... It was dumb so I sold it and made my own for about 87$ its a good way to save money and you will see a better result from making your own vs. K&N... There are several write ups on how to do it and you need very little skill to get it done... As far as the headers go... the only one you can afford on a budget are the Pacesetters... never used them but im sure some one will let you know how they turned out on your car... you have enough money to build a decent car... jus do your research before you blow it on junk... If you need anything myself and the fellow members of GPF will be glad to point you in the right direction...
  16. #16 Re: $750 to spend what are the must do mods??
    Weymouth, MA
    thanks and how come you see better performence from the intakes you make yourself
  17. #17 Re: $750 to spend what are the must do mods??
    Quote Originally Posted by Enjoijoe View Post
    Because the K&N blows. Heat soak. FAIL. Oh, that and the fact it costs over $300.
  18. #18 Re: $750 to spend what are the must do mods??
    Dover, DE
    http://www.grandprixforums.net/fwi.php
    Should cost no more that 90$ and you will see a tremendous gain over stock... not to mention the fact you have 200$ left for more parts...
  19. #19 Re: $750 to spend what are the must do mods??
    Yup...price and function. That and save your money and get some Pacesetter's and have them welded...for the price you can't beat it.
    http://www.grandprixforums.net/f73/l...ion-16085.html
  20. #20 Re: $750 to spend what are the must do mods??
    Weymouth, MA
    How do the intake make the s/c sound?? I can't wait to scare people haha.
  1. First Mods, what should they be?
    By SteelCityTA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2009, 04:57 PM
  2. I've got $800 to spend on my GP GT...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 04:04 PM
  3. Not how I wanted to spend my Sunday
    By jester in forum The Rant Forum
    Last Post: 02-09-2008, 06:37 PM
  4. best first mods to do
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2007, 07:50 AM
