Vehicle idle for about 10 seconds then it shuts down. I have replaced the fuel pump, inline resistor and the idle control valve and it still shuts down after a few seconds. Can anyone advise?![]()
No codes, it starts with no problems it only stays on for about 10 seconds. However, it will at times run for a day or two with no problems and then it starts acting up again. Oh hey thanking for trying to help.
No, No security lights. Hey do you think that a clogged exhuast cat converter could also be the problem?
GTP between the years of '97-'00?
Probably sounds like this
So I should replace the relay I quess. Thank you gentleman for your assistance this has been very helpfull.
well that is just the bypass, your fuel pump resistor is bad most likely
Ok, I bend the tab and the car works. However, I have already replaced the inline resistor once. You think I need to get another one or is there a wiring problem.
