The fuel rail is a series of metal pipes that are hooked up to all your injectors and run aroud and over your blower carrying pressurised fuel. On the metal rail along the front-side of the blower is a test port with a shader valve (same as an air tire one) you can check you pressure buy hooking a gauge up to it.
