Thread: silicone gasket need help quick...
Results 1 to 20 of 21
gotboost3 silicone gasket need help... 08-18-2009, 02:28 PM
Scimmia Re: silicone gasket need help... 08-18-2009, 02:52 PM
Sabrewings Re: silicone gasket need help... 08-18-2009, 02:57 PM
minichopper6hp Re: silicone gasket need help... 08-18-2009, 04:00 PM
gotboost3 Re: silicone gasket need help... 08-18-2009, 04:09 PM
minichopper6hp Re: silicone gasket need help... 08-18-2009, 04:10 PM
gotboost3 Re: silicone gasket need help... 08-18-2009, 04:11 PM
minichopper6hp Re: silicone gasket need help... 08-18-2009, 04:12 PM
gotboost3 Re: silicone gasket need help... 08-18-2009, 04:13 PM
minichopper6hp Re: silicone gasket need help... 08-18-2009, 04:17 PM
gotboost3 Re: silicone gasket need help... 08-18-2009, 04:17 PM
minichopper6hp Re: silicone gasket need help... 08-18-2009, 04:18 PM
gotboost3 Re: silicone gasket need help... 08-18-2009, 04:26 PM
minichopper6hp Re: silicone gasket need help... 08-18-2009, 04:29 PM
gotboost3 Re: silicone gasket need help... 08-18-2009, 04:44 PM
minichopper6hp Re: silicone gasket need help... 08-18-2009, 05:06 PM
gotboost3 Re: silicone gasket need help... 08-18-2009, 08:18 PM
JJ91284 Re: silicone gasket need help... 09-01-2009, 06:54 PM
BoostJunki3 Re: silicone gasket need help... 09-01-2009, 07:01 PM
JJ91284 Re: silicone gasket need help... 09-01-2009, 07:18 PM
BoostJunki3 Re: silicone gasket need help... 09-01-2009, 07:24 PM
  1. #1 silicone gasket need help quick...
    Donating Users
    Plainfield, IL
    got some silicone sheets to make my own sc gasket....what i wanna know if can i not cut out the passage between the lim and sc for the egr to block it off so i dont have to worry about the ebr blockoff plate on my LIM leaking?? is this safe or can that piece eventually get sucked out?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: silicone gasket need help quick...
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The problem is that the air under the silicone would be at atmospheric pressure. Exposing the other side of the silicone to vacuum can't be good for it, not even accounting for the temperature changes messing with the pressures. Better to just cut a hole.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: silicone gasket need help quick...
    Barksdale AFB, LA
    If you're already sure that it's blocked off and just want added assurance, I suppose you could do it that way. I'm with Scimmia though. I don't know how strong the silicone is when laid across an entire hole like that and asked to deal with differential pressures. It's meant to be squeezed between two parts.
    2009 Subaru Impreza WRX STI
  4. #4 Re: silicone gasket need help quick...
    Banned - Busted For Scamming
    Feb 2009
    The silicone is pretty strong, i wouldnt see why you couldnt do it that way.
  5. #5 Re: silicone gasket need help quick...
    Donating Users
    Plainfield, IL
    so yes or no mini? would you stake a motor on it? lol
  6. #6 Re: silicone gasket need help quick...
    Feb 2009
    The hole isnt that big, the silicone is pretty strong. Id do it, thats all im saying, its your choice as always. If your gonna block it off anyways dont cut the hole.
  7. #7 Re: silicone gasket need help quick...
    Donating Users
    Plainfield, IL
    its already blocked off plus you will plug the egr hole when i do my ported blower from you right so this would be pointless?
  8. #8 Re: silicone gasket need help quick...
    Feb 2009
    Dont cut the hole then.
  9. #9 Re: silicone gasket need help quick...
    Donating Users
    Plainfield, IL
    ok then im thinking it will hold up good just wanted to be sure
  10. #10 Re: silicone gasket need help quick...
    Feb 2009
    When you gettin that blower?
  11. #11 Re: silicone gasket need help quick...
    Donating Users
    Plainfield, IL
    which hole would it be again?
  12. #12 Re: silicone gasket need help quick...
    Feb 2009
    Those 3 holes to the right of the picture, that form a triangle, dont cut any of them.
  13. #13 Re: silicone gasket need help quick...
    Donating Users
    Plainfield, IL
    ok then thanks for the quick responses! when you gonna be open for a ported case bro? i have the cash but dunno how long ill have it...
  14. #14 Re: silicone gasket need help quick...
    Feb 2009
    Ive got some people in front of you but if you need it done soon just let me know, ill see what i can do, depending on what you want done with it. I thought you already put your snout on? You gonna take all that back off again?
  15. #15 Re: silicone gasket need help quick...
    Donating Users
    Plainfield, IL
    i gotta pull the blower any way i think my coupler got messed up while putting the new snout on its rattling a bit...could you have it done in a week if i payed you thurs?
  16. #16 Re: silicone gasket need help quick...
    Feb 2009
    Ill have to let you know tomorrow as i will have a better idea of how much stuff i have left to do.
  17. #17 Re: silicone gasket need help quick...
    Donating Users
    Plainfield, IL
    this is what i ended up making....found a silicone bakign sheet that is actually internally threaded for added rigidness and its approved up to 500*F
  18. #18 Re: silicone gasket need help quick...
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Quote Originally Posted by gotboost3 View Post
    Where did you pick up this bottom silicone sheet from. I'm aware of the ones at target, but I'd like to take a look at this one as well.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  19. #19 Re: silicone gasket need help quick...
    Joliet, IL
    bed bath an beyond...12$ works great!
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  20. #20 Re: silicone gasket need help quick...
    Schaumburg, IL
    Quote Originally Posted by BoostJunki3 View Post
    Thanks
    Thats this right here right?
    Bed Bath & Beyond - Professional Silicone Baking Mat
    I'll have to check out my local Bed Bath & Beyond
  1. Lim gasket
    By cardiffGIANT98gtp in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 11:21 PM
  2. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  3. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
  4. LIM gasket
    By gtpinsc in forum General Tech Discussion
    Last Post: 10-21-2008, 03:37 AM
