View Poll Results: Have You Had To Replace Your Camshaft Position Sensor
Voters
14. You may not vote on this poll
  • Yeah, Ive had to replace it once
    5 35.71%
  • Yeah, Ive had to replace it twice
    0 0%
  • Yeah, I keep spares on my key chain it goes bad so often
    0 0%
  • No. What the heck is a camshaft position sensor
    9 64.29%
Thread: Trouble History With Camshaft Position Sensor
Results 1 to 15 of 15
  1. #1 Trouble History With Camshaft Position Sensor
    Oklahoma
    Im doing a poll to see how many of you have had trouble with your Camshaft Position Sensor. Specifically I want to collect information on multiple sensor replacements.
    Please, PLEASE, be serious and keep things on topic. I joke around a lot because I want to keep things light and fun, but I need the information to be as accurate as possible and all the participation that can be had.
  2. #2 Re: Trouble History With Camshaft Position Sensor
    ive never had to change mine, but i know how to if i ever need to.
    as i recall, the symptoms are that the car starts, but dies shortly thereafter and you cant keep it running.
  3. #3 Re: Trouble History With Camshaft Position Sensor
    Oklahoma
    Yep, in some cases you will not even be able to start it.
  4. #4 Re: Trouble History With Camshaft Position Sensor
    Oklahoma
    Bump. You mean to tell me that Bio was the only one that had any input on this?
  5. #5 Re: Trouble History With Camshaft Position Sensor
    PA
    From my experience on the forums, the crank position sensor is more likely to go bad than the cam position sensor. I believe, but don't quote me, that if the cam position sensor goes bad, the car will still run, but timing advance won't work. So your car will be very sluggish. But a bad crank position sensor will not let the car run at all.
    And I have never replaced either.
    2001 GSE
  6. #6 Re: Trouble History With Camshaft Position Sensor
    Oklahoma
    Quote Originally Posted by Zef_66 View Post
    You are right to a point. If the side of the CPS that controls the tach signal goes bad, it may stall or you'll loose traction control but it will in many cases will still run. If the side that controls spark goes out, then obviously the engine wont run.
  7. #7 Re: Trouble History With Camshaft Position Sensor
    PA
    If you want to move this to another thread, feel free to keep this one clean.
    I am not electronic guru or anything, but I would image the crank position sensor just measures the position of the crank at certain times and reports them to the PCM. From there, the PCM will tell the tach what RPM to read. Also, the PCM will tell the ICM when to fire what cylinder based on the appropriate spark tables. And the traction control is also controlled through the PCM based on the measured and controlled sprak. Again, don't know for sure, but my guess is that spark, TC, and tach are all controlled by the same sensor reading of the CPS and when that sensor goes bad, everything gets fubared.
    2001 GSE
  8. #8 Re: Trouble History With Camshaft Position Sensor
    Oklahoma
    I had a diagram somewhere that showed the layout of the CPS and its signals. All of them, if I remember correctly went directly to the Ignition Control Module, then from there to the PCM. I'll see if I can dig it up.
    What made it odd is that the CPS and Cam sensor operated off 10vdc which was really weird and I couldnt figure out how they were stepping that down from the normal system voltage until I saw it went through the ICM which apparently is providing some voltage regulation. But there are two distinct signals provided by the CPS triggered by the interrupters on the back of the harmnonic balancer.
  9. #9 Re: Trouble History With Camshaft Position Sensor
    PA
    Good to know. I never really looked into it. And since you looked at the diagrams, I will take your word for it.
    2001 GSE
  10. #10 Re: Trouble History With Camshaft Position Sensor
    Oklahoma
    Nah, dont take my word for it, Im just as fallible as anyone and as subject to making mistakes as anyone. But I did post up the diagrams, they just were in another thread somewhere dealing with a Coolant Sensor issue.
  11. #11 Re: Trouble History With Camshaft Position Sensor
    SE Level Member comongoose's Avatar
    Jan 2009
    Gainesville, Fl
    I wonder if this is my problem. Click to this thread to see what i wrote.
    http://www.grandprixforums.net/f18/i...use-14267.html
    -1999 GTP...Work in Progress! L26 bottom end, K&N HAI, ZZP MPS 3.5" pulley, headers, custom intake, 180 therm., 1.9 rockers
    -1996 Acura TL
    -1995 Trans Am...SOM beast...RIP.
  12. #12 Re: Trouble History With Camshaft Position Sensor
    lutz, fl
    this is sounds like the issue i've been having. it just got worst tonight and i almost didn't make it home. had the codes checked a few weeks ago and it threw the code for the cam shaft positioning sensor. didn't realize that it would get this bad this quick.
  13. #13 Re: Trouble History With Camshaft Position Sensor
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    i've only had to replace mine once so far
  14. #14 Re: Trouble History With Camshaft Position Sensor
    Knock on wood...I've never had to replace the CPS either, but damn I am on the 3rd Motor LOL
  15. #15 Re: Trouble History With Camshaft Position Sensor
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    ive havent had to replace mine yet. i just bought the car in november and have put about $3000 in repairs into it, so who knows with this pile of sh**, i might be replacing mine next week
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  1. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  2. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  3. P1810 Trouble Code - TFP Valve Position Switch Circuit
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2008, 11:03 PM
  4. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
