View Poll Results: Have You Had To Replace Your Camshaft Position Sensor
Voters
14. You may not vote on this poll
  • Yeah, Ive had to replace it once
    5 35.71%
  • Yeah, Ive had to replace it twice
    0 0%
  • Yeah, I keep spares on my key chain it goes bad so often
    0 0%
  • No. What the heck is a camshaft position sensor
    9 64.29%
Thread: Trouble History With Camshaft Position Sensor
Results 1 to 15 of 15
  1. #1 Re: Trouble History With Camshaft Position Sensor
    Oklahoma
    I had a diagram somewhere that showed the layout of the CPS and its signals. All of them, if I remember correctly went directly to the Ignition Control Module, then from there to the PCM. I'll see if I can dig it up.
    What made it odd is that the CPS and Cam sensor operated off 10vdc which was really weird and I couldnt figure out how they were stepping that down from the normal system voltage until I saw it went through the ICM which apparently is providing some voltage regulation. But there are two distinct signals provided by the CPS triggered by the interrupters on the back of the harmnonic balancer.
  2. #2 Re: Trouble History With Camshaft Position Sensor
    PA
    Good to know. I never really looked into it. And since you looked at the diagrams, I will take your word for it.
    2001 GSE
  1. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  2. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  3. P1810 Trouble Code - TFP Valve Position Switch Circuit
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2008, 11:03 PM
  4. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
