Yeah, Ive had to replace it once
Yeah, Ive had to replace it twice
Yeah, I keep spares on my key chain it goes bad so often
No. What the heck is a camshaft position sensor
If you want to move this to another thread, feel free to keep this one clean.
I am not electronic guru or anything, but I would image the crank position sensor just measures the position of the crank at certain times and reports them to the PCM. From there, the PCM will tell the tach what RPM to read. Also, the PCM will tell the ICM when to fire what cylinder based on the appropriate spark tables. And the traction control is also controlled through the PCM based on the measured and controlled sprak. Again, don't know for sure, but my guess is that spark, TC, and tach are all controlled by the same sensor reading of the CPS and when that sensor goes bad, everything gets fubared.
