He has the modded 1.9's from ZZP I think. Only downside is since you have the PCM and it shifts at 6200 you are going to need stronger valve springs...unless you get the rockers and turn the shift points down to 6,000 or less. Otherwise with the higher lift you are going to get valve float if you have stock springs and shift over 6K. Just something to keep in mind
