Thread: what to do next?
Results 1 to 20 of 31
  1. #1 what to do next?
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Hey guys. I'm at kinda a crossroads right now. I was wpnderin what everyone thinks I should do next to my car for go fast parts. I trust u guys more than the tech guys from a company so here it is. I've got a basic 3.4 setup with 180 tstat,3" catless dp,plog,dhp pcm,cai,and tb spacer. I've already talked to bio(thanks for the input nick) and was wonderin where I should go. I don't have a ton of money,but some say 1.9 rockers maybe? Intercooler? And from what company?thanks guys
  2. #2 Re: what to do next?
    TDCRacing
    Guest
    Since you already have a down pipe and p-log. There is no need for headers.
    We sell intercoolers for 450 bucks. For a Stage 2 phenolic version.
    Would you be willing to put a cam in your car? If not rockers are the next best thing.
  3. #3 Re: what to do next?
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    That's the price of your IC kit?
    2009 Subaru Impreza WRX STI
  4. #4 Re: what to do next?
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Just the price of the phenolic intercooler itself.
  5. #5 Re: what to do next?
    Apr 2009
    shawnee, kansas
    Well hell that's not a bad price for a full size. And prob not on the cam but I was thinkin pretty hard bout rockers
  6. #6 Re: what to do next?
    TDCRacing
    Guest
    Just let me know i'd be glad to help.
    I used to have 1.9 rockers. When I had the 3.4 and the p-log and DP. The car was pretty fast. It's a whole nother beat though when you have a full size I/C, 2.8 and a XP cam.
    If you do go with the rockers don't go broke with ZZP's but instead get your self a good set of ROLLER rockers.
  7. #7 Re: what to do next?
    Apr 2009
    shawnee, kansas
    I will thanks. But rollers r more expensive right? What's wrong with zzps?
  8. #8 Re: what to do next?
    TDCRacing
    Guest
    The problem with ZZP's is they charge a core on their rockers now. And they are almost as much as rollers. And the difference in valve train stability and extra power you will get out of the roller rockers is well worth the money.
  9. #9 Re: what to do next?
    Apr 2009
    shawnee, kansas
    Ah I see. Well ill take that into consideration. Roller rockers would b a nice touch. R rockers hard to change out? Need any special tools?
  10. #10 Re: what to do next?
    TDCRacing
    Guest
    Nope nothing special. An hour job tops (and that's only because you have to take the alternator off to remove the rear valve cover.
    Other than that a 3/8 ratchet and a 3/8 socket (I think it's a 3/8 socket.)
  11. #11 Re: what to do next?
    Apr 2009
    shawnee, kansas
    Right on. Sounds pretty easy. I'm new to these cars but I've done all my upgrades myself so I'm sure I can do it. So which one gives the more bang for the buck? Rockers would b easier to install that's for sure
  12. #12 Re: what to do next?
    TDCRacing
    Guest
    Best bang for the buck would be the cam for sure. I would get nothing less than somthing similar to a XP to make it worth while.
    But your looking at needing valve springs also. If your not willing to do all of that then I would just throw some roller rockers on it.
  13. #13 Re: what to do next?
    my rockers will be up for sale soon. no core charge on these babies.
  14. #14 Re: what to do next?
    Donating Users blowfishRus6's Avatar
    g.a.
    rockers were very easy to change out. i LOVE my roller rockers.
    i would also suggest meth injection in there some where.
    parker, what would a complete full size intercooler kit cost. fmhe, pump, core.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #15 Re: what to do next?
    TDCRacing
    Guest
    Quote Originally Posted by blowfishRus6 View Post
    FMHE 150.00
    Intercooler 450.00
    Bosch Cobra pump with harness 119.00
    The intercooler it's self is 200 bucks cheaper than ZZP's aluminum version!
  16. #16 Re: what to do next?
    Apr 2009
    shawnee, kansas
    What do u have bio? How much?
  17. #17 Re: what to do next?
    He has the modded 1.9's from ZZP I think. Only downside is since you have the PCM and it shifts at 6200 you are going to need stronger valve springs...unless you get the rockers and turn the shift points down to 6,000 or less. Otherwise with the higher lift you are going to get valve float if you have stock springs and shift over 6K. Just something to keep in mind
  18. #18 Re: what to do next?
    Apr 2009
    shawnee, kansas
    Yeah I read about the shift rpm problem on zzps website. Yeah that pcm raised my shift points alright. So bios just got the modded 1.9s and not rollers huh? Well I wonder how much? I was never plannin on doin a cam or valvesprings to my car. Would rockers change driveability?
  19. #19 Re: what to do next?
    if it looks like it is shifting at 6200 on the tach then it is shifting at 6000 truly. the tach is off and going higher than it is actually going.
    yes, the ZZP modded 1.9s are on my car. they work great on stock valve springs. they really wake up the car for the price of them. i was planning on selling them for $200.
  20. #20 Re: what to do next?
    Moore, Oklahoma
    The hell they do... I have a broken stock spring in my garage from running my Intense 1.9 rockers. I was only shifting at 6k too, never any higher. I ran the rockers 60,000 miles before the spring broke. The WASN'T a fluke deal either, there are several on ClubGP who have had this happen too with much lower miles on there rocker setup.
    Don't halfass it, if your gonna buy rockers do the springs/retainers too... unless you want to drop a valve. While you're in there you might as well replace the seals too...
    Shawn W. Larsen
