Thread: key stuck in ignition?
Results 1 to 12 of 12
jaketrey32 key stuck in ignition? 05-14-2009, 09:37 PM
1998xGTP Re: key stuck in ignition? 05-14-2009, 09:44 PM
02blackgpgt Re: key stuck in ignition? 05-14-2009, 09:45 PM
02blackgpgt Re: key stuck in ignition? 05-14-2009, 09:56 PM
1998xGTP Re: key stuck in ignition? 05-14-2009, 09:59 PM
02blackgpgt Re: key stuck in ignition? 05-14-2009, 10:18 PM
1998xGTP Re: key stuck in ignition? 05-14-2009, 11:12 PM
Bio248 Re: key stuck in ignition? 05-14-2009, 10:09 PM
GeddyLee Re: key stuck in ignition? 05-15-2009, 02:01 AM
jaketrey32 Re: key stuck in ignition? 05-15-2009, 06:46 AM
jaketrey32 Re: key stuck in ignition? 05-15-2009, 04:26 PM
99gpse Re: key stuck in ignition? 05-15-2009, 05:28 PM
  1. #1 key stuck in ignition?
    Apr 2009
    illinois
    i can not get the key to turn to the off posistion to pull the key out. Any suggestions?? i have the battery disconnected because i'm taking it to get checked because it keeps dying. not sure if that is due to the ignition problem, or the new cd player i installed? thanks!!!
  2. #2 Re: key stuck in ignition?
    Dec 2008
    Canada
    Quote Originally Posted by jaketrey32 View Post
    Just throwing this out there, I don't think you can take the key out with the battery disconnected
  3. #3 Re: key stuck in ignition?
    GT Level Member 02blackgpgt's Avatar
    Jan 2009
    Kennesaw, GA
    had that same problem not a couple weeks ago. let me find the link that helped
    if it wasnt an automatic front wheel drive four door grandmas car it would be really nice
    Mods?? What the f#ck is a mod??
  4. #4 Re: key stuck in ignition?
    Jan 2009
    Kennesaw, GA
    i dont think the car dying and teh key getting stuck are related....
    ok so...
    the reason the key is stuck is called the igniton lock cylinder. its a useless piece of sh!t safety feature. first off to get the key out for now look up under the column and pull out the little cap piece covering a hole and jam a screwdriver in there to get it to release the key. then do this to remove the cylinder:
    Quote Originally Posted by Abrasive View Post
    Part looks like this...
    How to fix it:
    If you take the bottom cover off of the steering column you can get to it rather easy and remove the solenoid.
    1) tilt wheel all the way up and remove tilt wheel lever.... just pull, it comes out rather easy
    2) take out screws in bottom steering column cover.... torx bit
    3) pull off cover. you will have to tilt it a little to clear the rear clips.
    4) remove screw(s) holding in solenoid.... very small nut driver or pliers will do the trick.
    5) unplug wires to solenoid and discard solenoid into nearest trash can and save money for beer after job is complete
    6) reverse order to reassemble column
    7) use money saved from step 5 and go have a few beers
    thanks to abrasive. that post really helped me.
  5. #5 Re: key stuck in ignition?
    Dec 2008
    Canada
    Quote Originally Posted by 02blackgpgt View Post
    Mine was stuck when my battery died and i didn't have a replacement and my key got stuck :S and I didn't have to do what abrasive and you did I just replaced battery and turn it back and it was fine.
  6. #6 Re: key stuck in ignition?
    Jan 2009
    Kennesaw, GA
    Quote Originally Posted by 1998xGTP View Post
    hmm thats weird. when my battery died my key didnt get stuck...i guess i just got lucky.
  7. #7 Re: key stuck in ignition?
    Dec 2008
    Canada
    No clue but as soon as I put my new battery in it popped out and worked fine
  8. #8 Re: key stuck in ignition?
    if your steering wheel is locked in the wrong position then that will keep the key in there too.
  9. #9 Re: key stuck in ignition?
    St. Louis Mo.
    Moved to the correct area.
    James Shafer
    St. Louis MO
  10. #10 Re: key stuck in ignition?
    Apr 2009
    illinois
    Thanks guys, i have direction now, i'll let you know how it turns out.
  11. #11 Re: key stuck in ignition?
    Apr 2009
    illinois
    got the battery charged, and the key works fine now. Now i just need to figure out why my battery is getting drained. i had it checked at auto zone, battery is good, alternator had a peak amp of 215, which is about 105 amps to high. they suggested a bad ground or fusible link, anyone know where to find these on my 03?
  12. #12 Re: key stuck in ignition?
    GTP Level Member 99gpse's Avatar
    Dec 2008
    Freeman, SD.
    yes, if they battery is dead/ missing, the key will not come out. there is a manual override in the bottom of the steering column, you can put in a screw driver, and take it out. when the battery is removed, they key gets locked in. idk why they do it, but my Grand Am did the same thing.
    '90 Acura Legend LS V6 2.7 5MT ^
    '87 Acura Legend V6 2.5 5MT
    '94 Saab 900 SE V6 2.5 4AT
  1. Key stuck in ignition lock cylinder
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-17-2019, 10:47 AM
  2. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  3. 2005 GT Key stuck in dash mounted ignition
    By eebill in forum General Tech Discussion
    Last Post: 10-04-2009, 08:59 PM
  4. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
  5. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
