Thread: AC not working
Results 1 to 11 of 11
  1. #1 Re: AC not working
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    first sheck and see if their is voltage to the ac compressor clutch. take the wires off and test with a volt meter with the car calling for ac if you have voltage then the clutch if fried. most compressors, if they fail internally, will still pull in the clutch of lock up completely. i doubt thats the case. the only thing is i dont know if you can just buy the clutch. check autozone as they can also rant you the loaner tool to remove the clutch. worse case senario, get an ac delete and role down the windows lol good luck
  2. #2 Re: AC not working
    Michigan
    thanks, I will try to test the voltage, if it fried how hard it it to change out the compressor?
  3. #3 Re: AC not working
    Michigan
    I just looked at auto zone and they do just sell the clutch. I'm going to my parents tomorrow so I'm going to have my dad look at my unit. Hopefully we can determine the bad part. The clutch is only 60 bucks if thats it, the whole compressor assembly ranges from 260 to 370 on autozone. I'll hope for the cheaper part. I bet that would cost a lot to have a auto repair shop do that work.
  1. Help!!! Gas Gas gauge not working
    By PontiacGTPSE in forum General Tech Discussion
    Last Post: 07-09-2009, 12:30 PM
  2. AC Not Working
    By lzicc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2009, 06:04 PM
  3. DIC working?
    By Seagya in forum General Tech Discussion
    Last Post: 05-13-2008, 07:20 AM
  4. DIC not working
    By sausmonkey in forum General Tech Discussion
    Last Post: 04-25-2008, 11:21 AM
