Thread: Help!!! Gas Gas gauge not working
Results 1 to 12 of 12
  1. #1 Help!!! Gas Gas gauge not working
    SE Level Member PontiacGTPSE's Avatar
    Apr 2009
    Jackson, Michigan
    My gas gauge is not working correctly and so none of my DIC info is correct either, someone told me something about a new sending unit, please help with more info
    Thanks
  2. #2 Re: Help!!! Gas Gas gauge not working
    rockford illinois
    i have the same problem someone HELP!!!!
  3. #3 Re: Help!!! Gas Gas gauge not working
    GTP Level Member SuperSport's Avatar
    Michigan
    My gauge is dead too. Ive read multiple threads here and elsewhere that you can buy just the sending unit with the float for around 80-90 dollars, and just swap the pump to that. Ive read its an ACDelco brand. Problem is, I cant find it anywhere. All I can find is the sending unit with pump for like $400.
    So ya, any help would be great.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: Help!!! Gas Gas gauge not working
    PCM issue? Sounds wiring related...thats just my thought though...
  5. #5 Re: Help!!! Gas Gas gauge not working
    SE Level Member Feather Head's Avatar
    Wausau
    Mine is similar but it reads from full to half and kinda goes back up
  6. #6 Re: Help!!! Gas Gas gauge not working
    Feb 2008
    The problem is in the sending unit on the pump assembly. You can replace it with another fuel pump assembly for around $300-350, or go find a used assembly and just yank the sending unit out of it.
  7. #7 Re: Help!!! Gas Gas gauge not working
    Michigan
    Apparently all you need to do is clean the contacts on the rheostat...found this after some digging. Read post #7
    http://www.automotiveforums.com/vbulletin/t628417.html
  8. #8 Re: Help!!! Gas Gas gauge not working
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    ^ that is a possibility, but by no means a "sure thing" (like me and Becca, for instance) <kidding>
    I would agree that you're sending unit is bad - and that you can either A) replace the entire pump or B) get a sending unit out of a used pump. Personally - I'd go with A, because you have no idea what your getting with a used one - and for the amount of work involved - it would suck...a lot...to have to tear it open again just to replace the pump in the end.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  9. #9 Re: Help!!! Gas Gas gauge not working
    Michigan
    You and Becca? Arent you like 40?
    Anyways, dont know what else could go bad on the sending unit, looks like a pretty straight forward cleaning to me....I dont know, just staying hopeful I guess. Dont feel like dishing out 400 for a new pump assy.
    If the cleaning doesnt work then Ill stick with my trip odo.
  10. #10 Re: Help!!! Gas Gas gauge not working
    Easy with the old man jokes, dammit.
    I would give cleaning it a try - you're only out time - and not money. So you really can't lose.
    -Swash
  11. #11 Re: Help!!! Gas Gas gauge not working
    Michigan
    Its all good Swash.
  12. #12 Re: Help!!! Gas Gas gauge not working
    Indeed my good man...indeeeeed.
    -Swash
  1. Working on a digital gauge cluster project...
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 09-22-2009, 02:53 PM
  2. Boost Gauge Stopped Working
    By chipsdubbo89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 03:58 PM
  3. DIC working?
    By Seagya in forum General Tech Discussion
    Last Post: 05-13-2008, 07:20 AM
  4. DIC not working
    By sausmonkey in forum General Tech Discussion
    Last Post: 04-25-2008, 11:21 AM
