Thread: trans temp
Results 1 to 9 of 9
  1. #1 trans temp
    Donating Users
    Plainfield, IL
    whats the highest my trans should get on a hot day? i do have a lead foot i been seeing temps around the 220 area is that average, high/low?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: trans temp
    Outer Space
    I rarely see 220 on my daily drive... but have seen 210-215. Just make sure fluid is full, and you change it.
    When it gets 220... be easy on it. No need to blow your trans.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: trans temp
    Donating Users
    Plainfield, IL
    you think it could have something to do with my pacesetter cross over being super close to the trans and heatsoaking the trans temp sender and or radiating heat onto the trans case?
  4. #4 Re: trans temp
    Outer Space
    I dont think thats the issue, I have pacesetters as well....
    When is the last time you changed your fluid?
  5. #5 Re: trans temp
    Donating Users
    Plainfield, IL
    well on the daily drive i see about 180 to 200 basically my trans and engine stay about the same temp...under heavy driving racing i see about 220-230
  6. #6 Re: trans temp
    Donating Users
    Plainfield, IL
    just had my fluid changed recently when my trans was apart...but i dont know what kind of fluid they used when they filled it could that be an issue?
  7. #7 Re: trans temp
    Outer Space
    I personally dont think fluid type is going to help that much in temp reduction... but others might chime in.... 2 guys I know that have helped me do work on my car laughed at the Dexron VI i put in... b/c 10k miles into it ... it was brown like molasses and all burnt up.
    So from my experience, I dont think the fluid type is the major factor, rather that you change it on a maintenance schedule.
    Remember, the fluid is supposed to be red.... not brown.
  8. #8 Re: trans temp
    Barksdale AFB, LA
    When you're getting hard on it the torque converter is making a lot of heat. Just lay off and cruise to give it a chance to cool some. The stock fluid cooler built in to the radiator wasn't meant for constant beating on it.
    And your headers will not heat soak the temp sender. It's deep inside the trans away from outside influences.
    2009 Subaru Impreza WRX STI
  9. #9 Re: trans temp
    Donating Users
    Plainfield, IL
    cool thanks yeah so basically i drive too crazy....gotta calm it down lol
  1. Temp Reading
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2010, 09:30 AM
  2. Low temp. Stat
    By Rossko85 in forum 5.3L V8 (LS4)
    Last Post: 03-10-2009, 07:52 AM
  3. Temp light on not hot????
    By Logansrun in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2009, 05:18 PM
  4. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
