Thread: Temp light on not hot????
Results 1 to 2 of 2
  1. #1 Temp light on not hot????
    Feb 2009
    titusville
    Car is a 2002 gtp and I let the car sit for about 7weeks. When I started it up all good then temp light came on but the temp was about 160 and would not go over 60 whith all jerks and bucks picked up some dry gas and fuel cleaner light still on and removed the cap to the rad was not hot at all still bucking??? Any help
  2. #2 Re: Temp light on not hot????
    TDCRacing
    Guest
    Could be something clogged. Or a bad temp sensor and you are running hot. Checked the fluid?
  1. Temp Reading
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2010, 09:30 AM
  2. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  3. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  4. Temp fluctuation
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 10-11-2008, 08:28 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
