Thread: Intercooler
Results 1 to 7 of 7
gtp59 Intercooler 04-22-2009, 10:45 AM
JoshMcMadMac Re: Intercooler 04-22-2009, 11:21 AM
minichopper6hp Re: Intercooler 04-22-2009, 12:25 PM
JoshMcMadMac Re: Intercooler 04-22-2009, 05:20 PM
SyntheticShield Re: Intercooler 04-22-2009, 05:19 PM
minichopper6hp Re: Intercooler 04-23-2009, 07:48 AM
dagger Re: Intercooler 04-23-2009, 10:32 AM
  1. #1 Intercooler
    SE Level Member gtp59's Avatar
    La Crosse, WI
    I want to go intercooled but i would like to do a front mount system, does anyone have this and how do you do it? Send pics if you have them. Thanks.
  2. #2 Re: Intercooler
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    You have to run a Front Mount Heat Exchanger (FMHE) on an intercooler. The plate that goes between the supercharger and the engine is what transfers the heat out of the air going into the engine.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Intercooler
    Banned - Busted For Scamming
    Feb 2009
    i think he was referring to an actual front mount setup. some have done it in Australia and for our cars the general conclusion is that there is too much piping to make it run right.
    Logan
  4. #4 Re: Intercooler
    Waynesboro, PA
    Logan
    What you are referring to is an air-to-air setup, as opposed to the water-to-air setup that everyone uses. There is a reason we all run water-to-air.
  5. #5 Re: Intercooler
    Oklahoma
    Moved to the correct section.
  6. #6 Re: Intercooler
    Feb 2009
    although one day im still thinking of making a prototype.... maybe
    Logan
  7. #7 Re: Intercooler
    CT
    water to air is going to work better, water works better at getting rid of heat.
  1. SS intercooler help
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 09:09 PM
  2. zzp intercooler
    Last Post: 08-31-2008, 06:14 PM
  3. intercooler?
    Last Post: 08-04-2008, 12:53 AM
  4. SS intercooler ?'s
    Last Post: 06-25-2008, 12:11 AM
  5. ZZP FS intercooler....Will it fit??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 02:26 AM
