Thread: Windshield Wiper Pump
Results 1 to 4 of 4
  1. #1 Windshield Wiper Pump
    Apr 2009
    Romeo, MI
    First off, let me just say I used this website to fix my HVAC blower from another person's post, so kudos to you guys!
    Ok, so today I noticed that my wiper fluid was not spraying. I have adequate fluid, and the as far as I can tell the line isnt frozen. (Never had that problem anyway with my grand prix even though its outside in middle of no where michigan.) I noticed that it doesn't sound like the fluid pump is on when i attempt to clean the windshield, only think I can hear is the wiper action.
    So... is there any chance that the fluid pump has a fuse, I checked the manual and didnt see one. If not, is there somesort of relay i should check first. And finally, if all are no's and I need to replace the pump, am I correct that the pump can be accessed from the passanger side wheel well?
    Thanks for the help!
    I hope I posted in the correct location, if not, I wont mess up again, I promise .
  2. #2 Re: Windshield Wiper Pump
    SE Level Member StreetChariot's Avatar
    Cowtown, OH
    Check under the fender wall where the reservoir is. Have someone turn on the wash function and listen for sound coming from the reservoir.
    On my old MC I had a pump go out, and I picked one up from the junk yard for like 5$.
    If you go the junk yard route, go to a yard with a 30 day guarantee, or bring a battery with you (9V) to test out the pump while you are there.
    The pump more or less just plugs into the side of the reservoir, and is held in place with a rubber grommet.
    As for a fuse, check above the battery or inside the glove box. I'm not sure since I am not near my car ATM.
  3. #3 Re: Windshield Wiper Pump
    Oct 2008
    Omaha
    the same thing happened to my GP, i just replaced the pump and it works great now. the pump is inexpensive anyways, around $15 at napa. I just turned my wheels so that i didn't have to take the wheel off, it is a tight space but it is still easy to do. Just take off the wheel well cover thing, and you will see the pump right in there.
    hope that helps.
  4. #4 Re: Windshield Wiper Pump
    Apr 2009
    Romeo, MI
    Thanks everyone for the help, worked out perfectly.
    Now am I supposed to mark this post as solved or anything?
  1. Windshield Wiper Pump Broke again.....
    By Egleone6 in forum General Tech Discussion
    Last Post: 11-28-2008, 05:23 PM
  2. Windshield Wiper Question
    By BADAZGTP in forum General Tech Discussion
    Last Post: 08-20-2008, 10:56 PM
  3. Broken passenger windshield wiper help
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 04-09-2008, 03:11 AM
  4. windshield wiper help
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 02:48 PM
