Thread: which downpipe
Results 1 to 6 of 6
superv6 which downpipe 04-19-2009, 03:48 AM
Mvfootball1 Re: which downpipe 04-19-2009, 10:40 AM
Bio248 Re: which downpipe 04-19-2009, 10:58 AM
superv6 Re: which downpipe 04-19-2009, 11:05 AM
Bio248 Re: which downpipe 04-19-2009, 11:23 AM
98SilvermistGTP Re: which downpipe 04-19-2009, 06:41 PM
  1. #1 which downpipe
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Hey guys. Ik gettin a downpipe for the gtp and I was wonderin what I should get. Should I get the dp with highflow cat or dp with offroad pipe? What's the differences like sound performance?
  2. #2 Re: which downpipe
    SE Level Member Mvfootball1's Avatar
    Aug 2008
    Shoreview, Minnesota
    Get the ZZP 3 inch off-road catless DP. You will get a gain in performance, nothing crazy, but it is noticable. Not to mention its a necessity for any further modding you may do. As far as sound, its a little bit raspier inside the car, not loud though. I love it.
    '99 Buick Regal GS--PT-61 turbo, Air to Air intercooler, 1.9 rockers, #65 injectors, PEMs, DHP tuned, 3 in DP, 3 in exhaust w/ cut out, Harmon Performance transmission w/ 3k stall and trans-go shift kit. much much more!
  3. #3 Re: which downpipe
    there is no reason to run catless unless youre just too cheap to buy the high flow cat.
  4. #4 Re: which downpipe
    Apr 2009
    shawnee, kansas
    They mention something on their website about havin issues with the o2 sensor cuz of the cat delete. Does it through codes or effect perf. At all? What can I do to fix the o2 sensor problem?
  5. #5 Re: which downpipe
    it wont affect performance, but it will throw a code unless you disable the rear o2 code with a tune or you get an o2 simulator.
  6. #6 Re: which downpipe
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    If you get a downpipe without the cat, you will have to get the rear O2 simulator, which is damn near as much as just getting the cat in the first place. When I got my RT downpipe with cat about 4 or 5 years ago, the O2 sensor was banging against the body of the car and was very annoying. I went ahead and got the O2 simulator to do away with it. I am guessing the ZZP pipe has the correct placement so the rear O2 will not do that. The RT downpipes are way to expensive for what you get now.
  1. ZZP downpipe
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2008, 06:29 AM
  2. Zzp downpipe again.
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 10:07 AM
