Thread: Car kills going downhill
Results 1 to 7 of 7
  1. #1 Car kills going downhill
    SE Level Member gtp59's Avatar
    La Crosse, WI
    I have a 98 gtp and everytime i drive down a hill for an extended period of time my rpms drop and my car will eventually shut off. It will start up after that but will not idol right. After awhile it will work fine again but it is a pain being i live in wisconsin and all we have are hills. i need some input so i can get it fixed. thanks
  2. #2 Re: Car kills going downhill
    Feb 2008
    Is your check engine light on?
  3. #3 Re: Car kills going downhill
    why would going down a hill matter? does it do the same thing when you are going in the high rpm's and then let it coast? how does it idle?
    for some reason it sounds like it is surging when you are idling, but when you coast it drops down lower than idle and dies.
  4. #4 Re: Car kills going downhill
    La Crosse, WI
    it idles a little rough at times, where it will slightly go up and down. but not too bad. it wont kill when it just sits and idles just when i go down a large hill. could it be a bad mass air flow sensor?
  5. #5 Re: Car kills going downhill
  6. #6 Re: Car kills going downhill
    CT
    well considering that at an angle your gas tank is at an angle also that might be somewhere to start. Maybe a clogged fuel pump or something like that.
  7. #7 Re: Car kills going downhill
    GXP Level Member ryangtp89's Avatar
    Maine
    My money is on the maf or the tb is just dirty.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  1. Cheap Gas = KILLS!!
    By blueguy in forum Track Sessions and Kills
    Last Post: 11-04-2008, 03:40 PM
  2. Few kills just cruising around..
    By Bogers99GTP in forum Track Sessions and Kills
    Last Post: 11-02-2008, 10:20 PM
  3. good kills last night
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 08-13-2008, 08:18 PM
  4. my kills b/f expolded trans.
    By justwhisen in forum Track Sessions and Kills
    Last Post: 07-30-2008, 01:58 PM
  5. New kills from the 4th
    By DesQ27 in forum Track Sessions and Kills
    Last Post: 07-09-2008, 06:41 PM
