Thread: Water pump problems?
Results 1 to 6 of 6
  1. #1 Re: Water pump problems?
    Oklahoma
    Moved this to the correct area.
    No, you dont have to take off power steering pump. There are holes in the power steering pump pulley. You have to rotate the pulley around until one of the holes lines up with the bolt in the water pump and then you can get a socket through there and remove that last bolt.
    Its a little awkward but it works.
  2. #2 Re: Water pump problems?
    Apr 2009
    Illinois
    My husband said the last bolt he is trying to remove from the water pump lines up directly even with the top edge of the pulley. By rotating the pulley he still can't get a socket on it. Do you have any other suggestions? Thanks.
  1. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
  2. Quick question (water pump)
    By cgator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 08:03 AM
  3. Quick question (water pump)
    By cgator in forum General Tech Discussion
    Last Post: 09-21-2008, 10:13 PM
  4. 1.9 rr's 105#'s, water pump, lim, alls kinds of stuff..
    By kyle99gtp in forum General Tech Discussion
    Last Post: 05-12-2008, 11:39 PM
  5. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
