With mechanical gauge: my keyon FP was ~47psi. About 5 min after keyoff it had dropped to ~40psi. After an hour it was at like 30 psi. After overnight there was no pressure left on the gauge. It should hold some pressure even overnight.
Another thing it was doing was, idle FP was ~41 psi (a tad low); when I'd rev it by hand it would go up to ~45-ish, then when I let off it would drop down to 32-33 psi or so before returning back to 40-41.
Then I got an electronic FP sensor; here's what it was doing at WOT, before and after the pump swap:
This data is all in WOT (MAP ~100), collected through a/d converter on the PowrTuner. Note also that this data was collected (and the pump replaced) before I topswapped (i.e., L36); WOT fuel pressure is higher now, of course with an L67 FPR seeing boost.
As RPM (thus MAF, thus fuel demand) went up, the original pump was petering out badly on fuel pressure. With a new pump, fuel pressure stays solid all the way across. WOT KR went away, and IPW's backed off from near-static.
I'll try and do a longer test tonight and post up results.
Mine don't do that. If I rev mine it raises to close to 50 psi and goes bad to 44 psi. No sudden dips, no nothing.
Thanks for the info. I wish I could do the same test but I have no way of doing so unfortuneitly.
