Thread: Performance shift
Results 1 to 18 of 18
  1. #1 Performance shift
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Is performance shift supposed to light up on the screen in the middle of the dash that tells you the boost fuel mileage, etc. cause if you look at it in a certain way you can see where it lights up, but ive never seen it light up.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Performance shift
  3. #3 Re: Performance shift
    stanford Ky
    No i mean in the LED screen in the middle of the whole dash not the gauges. If you look you can see where it lights up at.
    99 gtp- sold
  4. #4 Re: Performance shift
    SE Level Member StreetChariot's Avatar
    Cowtown, OH
    Check the forums using search or use Google. I found tutorials on how to install the option using those methods months ago.
    In some cases you need to have your control module re-programmed with the option turned on to make it available. Some ECMs are already programmed for it. You also need the shifter with the button on it to enable/disable the option, or you need to wire up your own switch on the dash, etc. to control the option.
    I believe ZZP offers an "always on" Perf Shift option for control modules they program.
  5. #5 Re: Performance shift
  6. #6 Re: Performance shift
    stanford Ky
    I didnt know you could put a bulb in on the screen. I knew that you could on the perf shift light on the gauges. So i guess there are 2 perf shift lights on when perf shift is engaged
    99 gtp- sold
  7. #7 Re: Performance shift
    Cowtown, OH
    The DIC is an LED display, no light bulb needed... The Perf Shift and BOOST gauges are controlled by the control module... You have to have a programmed control module for those to show up...
  8. #8 Re: Performance shift
    stanford Ky
    I have performance shift wonder why they didnt make it work on the led display. because the green perf light works fine on my gauges when its on. Im about to get a DHP pcm will that allow the LED performance shift light work? My boost gauge works fine too
    99 gtp- sold
  9. #9 Re: Performance shift
    Jul 2008
    Germantown, Maryland
    I have performance shift but the lights dont light up either...
  10. #10 Re: Performance shift
    put a bulb in it.
    put a bulb in it.
    C'mon...Third times a charm?
  11. #11 Re: Performance shift
    Jul 2008
    i need a 3rd...
  12. #12 Re: Performance shift
    Jul 2008
    what bulb do I need btw? Also I swore I read about someone using a blue bulb... can't find it?
  13. #13 Re: Performance shift
    i would say it again, but i didnt know it was on the digital screen. i thought he was referring to the other side of it where youd need a bulb. i have a non-digital one, so i dont have any of the cool stuff.
  14. #14 Re: Performance shift
    Cowtown, OH
    Haha. Right on....
    As for the DIC... Did you pull it from a yard, or was it factory installed?
    Here is the guide for installing the DIC:
    1997-2003 Grand Prix Analog to Digital DIC Conversion - Car Forums and Automotive Chat
  15. #15 Re: Performance shift
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    Funny this thread is going, I might as well join in.
    Since the weather has warmed up, it seems my performance shift doesn't stay on. When I go over even the slightest bumps the performance shift light on my DIC flashes on and off. Does anyone know if I need to actually take the shifter apart and re-wire it or something? Any help would be appreciated.
    But to the original thread starter- yes, it should light up on your DIC when the button on the side of your shifter is engaged... don't have a fix though, sorry.
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  16. #16 Re: Performance shift
    GT Level Member nutcase's Avatar
    Washington State
    if you have a 98 gtp..the ps is above the fuel gauge.
    My car doesn't leak oil,
    It marks it's territory.
  17. #17 Re: Performance shift
    Jul 2008
    My "perf shift" light comes on in the gauge cluster. It's a bluish green. I am referring to the DIC. I can see it says "performance shift" on it but it does not light up. I'll look at those links, hopefully it can help me.
  18. #18 Re: Performance shift
    Washington State
    that one is not hooked up. I'd like to see if I can since its a decent place to put it.
  1. Performance Shift?????
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2009, 01:23 AM
  2. Performance shift
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 10:12 AM
  3. performance shift WTH?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-08-2008, 09:44 PM
  4. performance shift
    By Scott B in forum General Tech Discussion
    Last Post: 06-29-2008, 08:40 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
