Thread: blue headlights
Results 1 to 20 of 24
  1. #1 blue headlights
    SE Level Member smittrailfire's Avatar
    Oct 2008
    iowa
    im a looking for some information on blue headlights, is an Hid kit the best way to go? I have tryed the blue xenon blubs and they didnt work out
    do i need a kit to have really blue lights, just looking for things you like and maybe some pictures
  2. #2 Re: blue headlights
  3. #3 Re: blue headlights
    Oct 2008
    iowa
    the xenon are HID right? i have just tryed the bulbs
  4. #4 Re: blue headlights
  5. #5 Re: blue headlights
    May 2008
    staten island,NY
    HID's i have 8000k theyre blue
  6. #6 Re: blue headlights
    Banned
    Feb 2009
    Wilmington, MA
    I have 8000k, and have a bluish tint, if you want blue get 10000k or 12000k hids.
  7. #7 Re: blue headlights
    4300K is white. 6000K is blue. 8000K is purple. etc.
    it depends where you buy the bulbs and if you get cheap ones and what not, but what i listed above is the true color scheme in Kelvins.
  8. #8 Re: blue headlights
    Oct 2008
    iowa
    i have also tryed this- eBay Motors: BLUE XENON 894 FOG LIGHTS 04-06 PONTIAC GRAND PRIX (item 260385448033 end time Apr-01-09 13:54:31 PDT)
    I have had bad luck with those.
    they say they are a replacement stock bulb but do they need a ballast to work?
    anybody have a certain brand they like or have pictures,thanks dustin
  9. #9 Re: blue headlights
    Kansas
    go with 10k
    SOLD 1999 GT Silvermist TS
  10. #10 Re: blue headlights
    Jul 2008
    Tampa, FL
    i think i'm gonna go with 6k HID's when i get mine...
  11. #11 Re: blue headlights
    the higher you go with the Kelvin rating the less usable light there is and more color there is. i wouldnt go any higher than 8000K if you like to see at night.
  12. #12 Re: blue headlights
    Oct 2008
    iowa
    Gafford44 is that what you have in your profile picture?
  13. #13 Re: blue headlights
    Oct 2008
    iowa
    most of you would recomend the wiring harness modification also?
  14. #14 Re: blue headlights
    GT Level Member black98gt's Avatar
    Rochester NY
    go to Systems Integration Plus, Inc. - Main Page and order them, theyre like 62.00 to yer door.. You either need 9007 size bulb if you have a 97-03 or a 9006 size bulb if you have 04+. Get the 8000k bulbs. they ship fast and they have had nothing but positive remarks about them. you dont need the wiring harness, just make sure you have a really good ground and you wont get any flicker.
  15. #15 Re: blue headlights
    Aug 2008
    KCMO
    ^ all i see on there is pc stuff. how about a direct link?
  16. #16 Re: blue headlights
    May 2008
    Winnipeg, MB
    how often do you guys get flashed with your HID's?
    2007 Pontiac Grand Prix
  17. #17 Re: blue headlights
    Oct 2008
    iowa
    i decided i dont want to change my harness, im going to go with a bright white, what do some of you like? something really bright, (to the point people flash me on low beam)
    i hope i can find something bright that isnt a Hid bulb
  18. #18 Re: blue headlights
    Quote Originally Posted by tod1d View Post
    never, they should be aimed correctly just like regular headlights.
    Quote Originally Posted by smittrailfire View Post
    a lot of those 'xenon' halogen bulbs are actually worse than stock because they try to change the color so much that the light output is lowered.
  19. #19 Re: blue headlights
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    First off Some miss information in this thread:
    1. 43/4500k is Pure white
    - 6000k is ice white. Think of white LED in most cases.
    - anything after 4500k you are decreasing the light output.
    - Think if the K as a color spectrum ROY G BIV. The higher the k the more violet the light gets.
    2. 99.9% of aftermarket bulbs for stock replacement have less light output then the stock bulb had. This is because the bulb is tinted. Even the beloved sliver star has slightly less light out put because the bulb is tinted. The real silver star made by osram in Germany are the real deal as long with GE night hawks, Philips 50+. These will provide the most light output over all.
    3. The saying they should be aimed like regular headlamps is not 100% correct. This is because we do not have the lens for HIDS thus the beam pattern is not the same and hids systems are meant to be used with a system with a sharp cut off of light to prevent glare. So if anything you need to aim them down a bit.
    Yes HIDS will out preform halogen lamp system any day of the week as long as the reset of the system is designed for it. If it wasn't it is a gable
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  20. #20 Re: blue headlights
  1. Blue Laws
    By SlowM90 in forum Off Topic Discussion
    Last Post: 01-21-2009, 11:08 PM
  2. blue lights and blinkers
    By smittrailfire in forum Visual/Body Modifications
    Last Post: 10-03-2008, 08:55 AM
  3. Blue 3M Edition GTP
    By David99GTP in forum Off Topic Discussion
    Last Post: 08-12-2008, 12:49 PM
  4. Saphire Blue GTP
    By BringTheRain in forum Visual/Body Modifications
    Last Post: 06-25-2008, 12:47 AM
