Thread: Engine Swap
Results 1 to 3 of 3
  1. #1 Engine Swap
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    What would be involved in swapping a L32 for a L67? Just wondering because I know they (L32) have the drive-by-wire throttle body and a different pcm (can-bus) than the series II. I wouldn't think it'd be too much involved with it. Please help!
  2. #2 Re: Engine Swap
    Barksdale AFB, LA
    Use the wire harness and PCM from your current engine. Get an adapter to use the L67 TB on the L32's Gen V supercharger (ZZP makes one).
    2009 Subaru Impreza WRX STI
  3. #3 Re: Engine Swap
    yeap, sabre has got it. everything else is pretty much plug and play. just drop it in a go.
    if i were doing it though i would do an l26 block with an l32 upper. the m90 likes the higher compression so you dont have to spin it as fast to make the same power.
  1. L36 engine swap
    By themagicdustman in forum General Tech Discussion
    Last Post: 02-05-2009, 07:08 AM
  2. engine swap question!!!!
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 12:27 PM
  3. Engine swap
    By BankRupt in forum Off Topic Discussion
    Last Post: 07-19-2008, 11:06 AM
  4. engine swap
    By 3800John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2008, 02:53 PM
  5. Swap 3.8 (L67) into 3.1 engine compartment?
    By jerricho in forum General Tech Discussion
    Last Post: 05-17-2008, 12:07 AM
