Ill correct myself now before the even pickier ride my ass. There are no digital signals on guages.
If you use copper line NOT NYLON with copper ferrels** and nut it wont ever leak, I always put some good old petroleum jelly once I tighten the copper down, oil cant penetrate it so it wont leak.
D, what gauges did you get? colors?
These were in my last cockpit, my mino.
VDO pro cockpit series.
AM Pro Comp liquid filled water temp
AM Phantom boost gauge, Thats a 5900 rpm reading on the vacuum gauge, looks like 3 psi on an N/A motor.....hmmm
Also the Pro Comp 10K rpm Tach Pillar mounted.
I eventually made the gauge panels out of brushed sheet aluminum, still had the quick access on the old radio/hvac control area (gold panel).
