Thread: DRL delete on '04+ GP
Results 1 to 20 of 52
TNTSS DRL delete on '04+ GP 03-15-2009, 05:33 PM
PFCGONZOGP915 Re: DRL delete on '04+ GP 03-15-2009, 06:04 PM
TNTSS Re: DRL delete on '04+ GP 03-16-2009, 12:48 AM
silvervipertb Re: DRL delete on '04+ GP 04-03-2009, 11:56 PM
tod1d Re: DRL delete on '04+ GP 04-04-2009, 07:38 AM
WhiteDevil Re: DRL delete on '04+ GP 04-04-2009, 10:12 AM
TNTSS Re: DRL delete on '04+ GP 04-04-2009, 05:05 PM
silvervipertb Re: DRL delete on '04+ GP 04-05-2009, 02:40 AM
WhiteDevil Re: DRL delete on '04+ GP 04-04-2009, 05:27 PM
WhiteDevil Re: DRL delete on '04+ GP 04-05-2009, 07:29 AM
silvervipertb Re: DRL delete on '04+ GP 04-06-2009, 12:08 AM
silvervipertb Re: DRL delete on '04+ GP 04-07-2009, 10:09 PM
carl06GT Re: DRL delete on '04+ GP 04-07-2009, 11:18 PM
silvervipertb Re: DRL delete on '04+ GP 04-19-2009, 09:08 PM
carl06GT Re: DRL delete on '04+ GP 04-19-2009, 09:38 PM
vailskier3 Re: DRL delete on '04+ GP 06-27-2009, 08:49 PM
silvervipertb Re: DRL delete on '04+ GP 04-20-2009, 03:27 AM
carl06GT Re: DRL delete on '04+ GP 04-20-2009, 09:31 AM
dluxxone Re: DRL delete on '04+ GP 05-06-2009, 07:01 PM
silvervipertb Re: DRL delete on '04+ GP 05-07-2009, 10:08 AM
carl06GT Re: DRL delete on '04+ GP 05-07-2009, 10:51 AM
RedDawnGXP Re: DRL delete on '04+ GP 05-17-2009, 11:05 PM
massivesystem Re: DRL delete on '04+ GP 05-17-2009, 11:11 PM
RedDawnGXP Re: DRL delete on '04+ GP 05-17-2009, 11:43 PM
massivesystem Re: DRL delete on '04+ GP 05-17-2009, 11:53 PM
RedDawnGXP Re: DRL delete on '04+ GP 05-17-2009, 11:56 PM
massivesystem Re: DRL delete on '04+ GP 05-18-2009, 12:36 AM
RedDawnGXP Re: DRL delete on '04+ GP 05-17-2009, 11:46 PM
vailskier3 Re: DRL delete on '04+ GP 06-04-2009, 01:37 PM
carl06GT Re: DRL delete on '04+ GP 06-04-2009, 01:48 PM
tod1d Re: DRL delete on '04+ GP 06-04-2009, 09:02 PM
SuperSport Re: DRL delete on '04+ GP 06-27-2009, 01:35 PM
tod1d Re: DRL delete on '04+ GP 06-28-2009, 08:34 AM
vailskier3 Re: DRL delete on '04+ GP 06-28-2009, 05:16 PM
carl06GT Re: DRL delete on '04+ GP 06-27-2009, 11:02 PM
silvervipertb Re: DRL delete on '04+ GP 06-29-2009, 12:11 AM
carl06GT Re: DRL delete on '04+ GP 06-29-2009, 12:30 PM
tod1d Re: DRL delete on '04+ GP 06-29-2009, 01:36 PM
vailskier3 Re: DRL delete on '04+ GP 06-29-2009, 08:19 PM
carl06GT Re: DRL delete on '04+ GP 06-29-2009, 10:16 PM
tod1d Re: DRL delete on '04+ GP 06-30-2009, 05:19 AM
vailskier3 Re: DRL delete on '04+ GP 06-29-2009, 10:52 PM
carl06GT Re: DRL delete on '04+ GP 06-29-2009, 10:55 PM
vailskier3 Re: DRL delete on '04+ GP 07-02-2009, 01:10 AM
RedDawnGXP Re: DRL delete on '04+ GP 07-03-2009, 08:13 PM
vailskier3 Re: DRL delete on '04+ GP 07-05-2009, 10:37 PM
RedDawnGXP Re: DRL delete on '04+ GP 07-06-2009, 11:17 AM
WHT98GTP Re: DRL delete on '04+ GP 08-05-2009, 05:37 PM
daiadvisor Re: DRL delete on '04+ GP 09-06-2009, 07:30 PM
  1. #1 Re: DRL delete on '04+ GP
    GT Level Member massivesystem's Avatar
    Apr 2008
    Quote Originally Posted by RedDawnGXP View Post
    Short of attempting to completely eliminate the DRL's for an HID kit, you could run a relay harness to power the HID's. The DRL's (operating on reduced power) will still have enough voltage to turn on the relay which will in turn draw a full 12 Volts from the battery to the HID ballasts. The only problem is that the HID's would always be on. Properly installed HID's will give you anywhere from 2000-3000 operational hours compared to 300-1000 with halogen so you wouldn't wear them out by having them always on. It would be more of a matter of just NOT wanting the DRL's.
    Alternatively, has anyone considered this:
    Run a relay harness to the HID kit that is triggered by the parking lamps. Doing this would mean that the DRL's wouldn't interfere with HID operation since the parking lamps don't come on with the DRL's. Also, since the parking lamps automatically come on with the headlights the stock headlight switch will still operate normally. The drawback to this would be that you couldn't run JUST the parking lamps WITHOUT the headlights coming on. Does anyone care about that? Probably not. Another problem would be the HID's coming on when the parking lights flash when the doors are unlocked. This would be a problem because they would blink on then off with the parking lamps which can damage the bulbs and ballasts. I think the parking lights blinking with the locking and unlocking of the doors can be disabled via the DIC so this would not be a problem then. I did this on my buddy's 2002 Tahoe because he wanted the headlights to stay on when the highbeams were triggered because on the Tahoe the headlights go out when the highbeams come on which means you can't see anything 10' in front of your car. I wired the headlights to come on with the parking lamps and everything operated normally. This is a similar concept to what I am proposing for the Grand Prix.
    Finally, I have a 2007 GXP and when I deactivate the AUTO headlight feature my DRL's go off. I have no lights on at all, it's sweet. Is this just an option on the GXP model or are there some DIC settings that can deactivate the DRL's?
    I have a 2007 GP GT how what did you do to "deactivate the AUTO headlight feature " as noted above?
    thanks
    2007 Pontiac Grand Prix GT Series III 3.8 Super Charged
    AL 104's Plugs, 180* T-Stat, Tuned PCM , Custom CAI is complete and installed, AeroForce Interceptor gauge, Smoothflow 3.5 pulley with 0* KR, SSAC SS Headers. 6000K HID
  2. #2 Re: DRL delete on '04+ GP
    GT Level Member RedDawnGXP's Avatar
    Indiana
    Quote Originally Posted by massivesystem View Post
    thanks
    On your turn signal stalk, there is the headlight band that has the headlight, parking lamp and "AUTO" position. Turn that band down, it will click back into position. This toggles on and off the "AUTO" headlamp setting. It should have no bearing on the DRL but for some reason on my GXP it turns off the headlamp DRL's. Turning on my foglights also cuts my DRL's as well. Is this just with the GXP model?
  3. #3 Re: DRL delete on '04+ GP
    Apr 2008
    As for the DRL I can do that on my 07 GT also
    I did not have to use a harness for my HID
  4. #4 Re: DRL delete on '04+ GP
    Indiana
    You might want to consider using a harness even without the DRL's. The stock headlight harness cannot put out the required "in-rush" current of HID systems and therefore can cause the ballasts to go bad over time...that is unless you are using a digital HID kit that uses a significantly less amount of current at start up. BTW, nice Prix.
  5. #5 Re: DRL delete on '04+ GP
    Apr 2008
    I was thinking of using one. Thanks for the Nice Prix kudo's. I am getting ready to drop on my headers and put on my new 18" KV5 wrapped in GY F1's
  1. Delete
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 03-15-2009, 09:44 AM
  2. a/c delete
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2008, 11:09 AM
  3. delete
    By PWNED in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2008, 11:45 AM
