Thread: need help a.s.a.p.
Results 1 to 4 of 4
  1. #1 need help a.s.a.p.
    Jan 2009
    hammond, IN
    im ordering my new pcm from intense and need help on what to put into the tune for it and what some of the things mean such as-Please select your disabled DTC settings:
    Disable random/multiple misfire DTC's (ideal for vehicles with aftermarket camshaft) (+$20.00)
    Disable rear O2 sensor DTC's (+$20.00)
    Disable EGR DTC's (+$20.00)
    Disable EVAP DTC's (+$20.00)
    witch one should i choose and what does it mean?
    and what does this mean- Increase WOT ignition timing tables by up to 1 degree - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (<b>+$20.00</b>)
    any help would be great, thanks
  2. #2 Re: need help a.s.a.p.
    TDCRacing
    Guest
    I'll just respond to you're PM here.
    DTC = Diagnostic Trouble Codes. (What set's you're SES light off.)
    1. If you're getting a cam you want this disabled.
    2. If you're going to elimintae the cat you want this disabled.
    3. If you're going to be running an intercooler you need to disable it So you would want this disabled.
    4. If you're going to eliminate the EVAP on the car you want this disabled.
    5 This means that you will be running one degree higher timing when you are at WOT
  3. #3 Re: need help a.s.a.p.
    Jan 2009
    hammond, IN
    what is WOT and should i add any of the things on that list to the tunning or just leave what they have already set up automaticaly on that site and just click buy it now? this is everything it is now, should i change any of this? INTENSE-Racing.com: INTENSEā„¢ Reprogrammed 3800 Powertrain Control Module (PCM)
    thanks, damon
  4. #4 Re: need help a.s.a.p.
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    WOT stands for Wide Open Throttle. Or pressing the gas pedal down to the max.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
