Thread: pcm
Results 1 to 8 of 8
  1. #1 pcm
    Jan 2009
    hammond, IN
    can somebody send me the link to the pcm from intense so i can buy it cause im lost on were to go and what to pick when i get there, so if anyones owns a pcm from them can somebody point me in the right way please, thanks
  2. #2 Re: pcm
    Nov 2008
    Chicago
  3. #3 Re: pcm
    Jul 2008
    Tampa, FL
    Quote Originally Posted by FuglyGTP View Post
    lol
  4. #4 Re: pcm
    Feb 2008
    Quote Originally Posted by fuglygtp View Post
    x3 lol
  5. #5 Re: pcm
  6. #6 Re: pcm
    Jan 2009
    hammond, IN
    i know where the web site is and stuff and that igo to the pcm part but idont know what to do from there jsut cick buy it now? is all this stuff already what they have on it,
    INTENSE™ Standard PCM - $99.99
    Ideal for stock to slightly modded cars with induction mods, exhaust mods, smaller supercharger pulley and/or rocker arms - features removal of all speed limiters, higher shift points (~6,000 RPM)** and rev limiter (6,200 RPM) , proprietary transaxle shift behavior adjustments** including 'skip shifts', air/fuel adjustments, knock retard decay rate adjustment, cooling fan control adjustments (180°), cooling fans on at key-off for 180 seconds, elimination of Abuse Mode, Differential Scoring Protection, Supercharger Torque Management, etc.
  7. #7 Re: pcm
    you have to select the things you want on it. your options if your stock will probably look like this:
    -Standard PCM
    -Stock idle
    -Fans for 180* thermo
    -Stock WOT timing tables (unless you want to try for another degree or two, but youll need supporting mods for that)
    -increase the shift points to 6000
    you can disable some codes, but im not sure that you need/want to at this point.
  8. #8 Re: pcm
    Jan 2009
    hammond, IN
    my can has some exaugst work a smaller pulley a full intake and like 180 stat and colder plugs and stuff like that in it so i just want what that lil discription i posted said and im just wondering if all that comes on it already cause it doesnt list any of it to choose like the other stuff
pcm
