Well the canister works it sucks the rod up when you start the car and it push's it down when you rev it up. THe vaccum was cracked but it still worked. Could it be that valve on the supercharger.
But it could still have a leak. Spray everything down with carb or brake cleaner. That will find the leak. If it rev's up. You found you're problem.
