The ones I know:
Quote Originally Posted by adamlesandrini
I can find one fuse box, the one under the hood, but is that really the only one?
There should be another one on the passenger side of the dash.
she needs a new belt, can I replace this without removing the coolant tank?
Possibly, but it's usually pretty simple to just unbolt it and move it out of the way.
how do you release the tensioner on these engines?
Assuming it's like most modern cars, it'll have a spring loaded tensioner. Just put a breaker bar on the nut and rotate
she needs new transmission fluid, how many quarts do these transmissions take?
7.4 for a pan drop, ~13 total
and what is the procedure to drain and fill them?
Best way is to just drop the oil pan, replace the filter, and refill through the dipstick tube
any tips on removing the filter?
you can pry it off, but make sure to protect the case if you do, you don't want to screw up the gasket surface.
where is a sure spot to put jack stands under this car, front and back?
I always put them on the subframe, wherever I can find a good spot.
