Sounds like a resistor problem to me, i'd definatly check that out...
ok so im having the same problem. but mine was running just fine and now wont. have no fuel. i bent pin #85 over and still nothing. i have a VERY dim light (test light) at the fuel pump (low voltage) im assuming! does this mean the fuel pump itself is bad? i have already replaced both relays! and where is the resistor located?
