Thread: Adjust headlights
Results 1 to 2 of 2
  1. #1 Adjust headlights
    Jan 2009
    Westminster
    Hey guys,
    So I went to install my fwi today and what do you know that just as i get the headlight off and start trying to remove the fender bracket(that back bolt is a b*tch to get to, any suggestions on removing it?), clouds roll in out of nowhere and starts pouring. Got to rush and get everything back together and then I'm good.
    Well, now my drivers side headlight is way high, and was wondering how I adjust it. I havent had a chance to look at it in light yet, and im sure its something simple like just something you screw or adjust, but figured id ask so i know tomorrow when i go to fix it up. So, how do i lower it?
    Thanks
  2. #2 Re: Adjust headlights
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    There are two plastic tabs on the headlight bracket. It's easy to miss one of them when reinstalling the headlights, which will cause the headlight to be very wobbly and aimed wrong. I'd take the headlight out and make sure both tabs are inserted first.
    If that's not the problem, there are two E8 Torx screws used to adjust the headlight. They're located on top of the plastic bracket. The inboard one is for side to side adjustments, and the outboard one (on the corner near the turn signal) is for up/down adjustments.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  1. Adjust Windshield Wipers
    By Zef_66 in forum General Tech Discussion
    Last Post: 11-25-2008, 02:00 PM
  2. HELP I need better headlights for my 02 gp
    By logands in forum Visual/Body Modifications
    Last Post: 11-04-2008, 10:07 PM
  3. How do you adjust your parking brake?
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 10-13-2008, 07:08 PM
  4. Anyone know how to adjust parking brake shoes?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 09-17-2008, 10:01 PM
  5. Headlights
    By BankRupt in forum General Tech Discussion
    Last Post: 04-21-2008, 11:04 PM
