Thread: Beeping while driving
Results 1 to 12 of 12
boostjunky Beeping while driving 02-25-2009, 05:21 PM
dmoney01 Re: Beeping while driving 02-25-2009, 05:36 PM
FoSHO99 Re: Beeping while driving 02-25-2009, 05:53 PM
dmoney01 Re: Beeping while driving 02-25-2009, 05:55 PM
blowfishRus6 Re: Beeping while driving 02-26-2009, 12:56 PM
DanGTP Re: Beeping while driving 02-26-2009, 02:59 PM
Guest Re: Beeping while driving 02-26-2009, 08:05 PM
kingd44 Re: Beeping while driving 02-26-2009, 09:25 PM
SyntheticShield Re: Beeping while driving 02-26-2009, 10:06 PM
Guest Re: Beeping while driving 02-26-2009, 09:37 PM
kingd44 Re: Beeping while driving 02-26-2009, 09:41 PM
blowfishRus6 Re: Beeping while driving 02-26-2009, 10:45 PM
  1. #1 Beeping while driving
    Feb 2009
    Toronto, Ontario
    Hey everyone, My car is running great but today about 4 random times I heard the *Dinging* sound (as if your door was open) and it would ding about 3 times. it did it randomly throughout the day. All doors are closed, trunk closed and hood closed... any Ideas??
    Thanks
    All Motor Is Nice, But I'd Rather Be Blown!
    1999 GTP , Bronzemist, FWI, Resonator and U bend delete, 180* T-stat, HPTune.
  2. #2 Re: Beeping while driving
    Jan 2009
    hammond, IN
    mine does that when i leave the turning signal on for to long so that might be it
  3. #3 Re: Beeping while driving
    Jan 1970
    Maquoketa, Iowa
    Freezing rain + trunk did it to me.
    Trunk was closed, but I opened it and brushed all the ice and stuff off and closed it again and it was fine. It beeped at me for a few days and finally one time i caught that the trunk signal flashed on the DIC. It was never flashing all the time, just that instance.
  4. #4 Re: Beeping while driving
    Jan 2009
    hammond, IN
    that was a problem with me to lol but i just slammed it and all the ice fell off but now that its warmer out i noticed when you leave the turning signal on for a lil it warns you that it is on
  5. #5 Re: Beeping while driving
    Donating Users blowfishRus6's Avatar
    g.a.
    the dic should say what it is when it digs
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: Beeping while driving
    Feb 2008
    Sounds like you may have a door/trunk ajar switch on the fritz. Check your driver's door and the trunk. Those are the two most common places for these switches to fail in a car.
    These cars also alert you when they're low on fuel (mine used to...). There's also a possibility that the fuel level sending unit is shorting out and temporarily showing low fuel, thus causing the "dinger" to go off.
  7. #7 Re: Beeping while driving
    TDCRacing
    Guest
    Somehow my trunk kept getting opened. It beeped when i went over bumps and I was like ?? Cupple days later I noticed the truck was opened. You could barley tell though. It is still happening....I'm not sure if it's me accidently pressing the button on the remote or what....
  8. #8 Re: Beeping while driving
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    i hit my trunk button all the time and open it by mistake lol so annoying lol
    180 t-stat, wizaired cai, s&s headers, 3inch cat back exhaust,jpg plug wires, auto lite plugs, 3.4 pulley, and ovk pcm......rockers to come............next summer might go intercooled
  9. #9 Re: Beeping while driving
    Oklahoma
    Quote Originally Posted by TDCRacing View Post
    I was going to reply that Ive had this issue before and what TDC posted was my problem. the DIC only will report that something is open if its opened enough to actually release the switch that indicates so.
    Ive done as TDC and not closed my trunk well enough or popped it open and forgot that I had done so and would get the ding sound only when I went over a bump that was sufficient enough to cause the trunk lid to open up enough and loose contact with the indicator switch that triggers the DIC and the audible indicator.
  10. #10 Re: Beeping while driving
    TDCRacing
    Guest
    Maybe that'sthe problem with mine then. On my roomates transam it makes you hit the trunk button 2 times real quick in order for it to open. On his key pad the trunk button has 2X on it indicating you have to do so.
    I guess if mine had this I would not have this problem.
  11. #11 Re: Beeping while driving
    Feb 2008
    newyork
    that is def a smart idea lol
  12. #12 Re: Beeping while driving
    g.a.
    ahh. good to know
    its slow.
  1. Driving with Brights On ?!?
    By John02Hawk in forum The Rant Forum
    Last Post: 07-26-2009, 11:35 AM
  2. Bad driving habits
    By DesQ27 in forum Off Topic Discussion
    Last Post: 12-01-2008, 09:38 PM
  3. Driving Friends GTP
    By GreenPrix in forum Track Sessions and Kills
    Last Post: 11-20-2008, 04:56 PM
  4. while driving, BOC!
    By fst in forum The Rant Forum
    Last Post: 02-04-2008, 10:47 AM
  5. For those of you who text while driving...
    By flynn in forum Off Topic Discussion
    Last Post: 01-15-2008, 05:47 AM
