Thread: Subframe mount change?
Results 1 to 20 of 26
  1. #1 Re: Subframe mount change?
    Jul 2024
    New Mexico
    Quote Originally Posted by idrivejunk View Post
    Check to see if your subframe bolts are tight. The bushings are fine.
    I'd have to write a small novel here to explain. I do have pics but not a site to host them.
    The oil soaked rubber that is peeling off is inconsequential.
    ​Just lay down and reach under the car with an 18mm and tighten the bolts, you'll see.
    the back is tight forsure i have yet to check the front ones
  2. #2 Re: Subframe mount change?
    Jan 2014
    AR
    Quote Originally Posted by LivinCorrupt View Post
    Trans shop left mine loose and one rear eventually fell out before I figured it out. I was going to replace mounts also but found upon further inspection that oh... despite the oil soaking the originals are in fine shape. Just the lip of the metal shell rusts and that rubber around it comes loose but the meaty mount part is fine. Not worth the hassle to replace.
    ​I say tighten them with car on ground because if you were to jack it up by the front of subframe that may compress the fronts more and be misleading. Theres a sleeve in the bushings so tight is tight but well on the ground is easiest.
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. Front subframe mount?
    By 310toumad in forum Brakes/Suspension/Chassis
    Last Post: 06-13-2016, 01:07 PM
  3. subframe mount interchange
    By 91parkave in forum General Grand Prix Discussion
    Last Post: 04-26-2015, 08:19 PM
  4. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  5. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
