Thread: Subframe mount change?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Subframe mount change?
    St. Louis
    This -->2024_10_24_03_51_241.jpg Plus this-->
    Means I never have to worry about that ****ty oil sending unit leaking again. The oil gauge sending unit that goes with this gauge replaces the factory POS and doesn't leak. I've only worn one out, but no leaks.
    Subframe mount change? Attached Images
  2. #22 Re: Subframe mount change?
    Jul 2024
    New Mexico
    Quote Originally Posted by FordMan77 View Post
    is it hard to wire into the system?
  3. #23 Re: Subframe mount change?
    St. Louis
    Not really. Just a single wire with a ring terminal crimped on at the sending unit then run up to the gauge. Then you tap into a power source for the backlighting on the gauge itself so it comes on with your headlights. I used one of the fuses on the drivers side of the dash to wire mine. Probably the hardest part is getting the wire through the firewall to the dash. I'd have to look at mine and see where I ran it as I did it so long ago.
    FYI, if you do install a 2 or 3 gauge A-pillar cover you WILL loose some of your sightline to the left. Not much, but it's there. You get used to it. I will say it's really nice to be able to just glance over at eye level and know if there is an issue or not.
  4. #24 Re: Subframe mount change?
    Jul 2024
    New Mexico
    ok doesnt seem tooo bad lol what is the unit that replaces the actual sensor itself or is it like a kit with that gauge
    also do you have a link to where you got yours from?
  5. #25 Re: Subframe mount change?
    St. Louis
    Below is the gauge I went with. You could choose any 2 1/16" gauge for the pod. Don't get a mechanical gauge. You don't need to have an oil line inside the car.
    gauge- 3327- Just a moment...
    this includes the sending unit #2242
    I believe the threads in the factory oil filter adapter are 1/8NPT so you will need an adaptor
    When installing the sending unit into the oil filter housing only tighenen it to where it is snug and runs into the thread tape. Do NOT overtighen it or you will crack the housing.
  6. #26 Re: Subframe mount change?
    St. Louis
    And to fill the other hole on the A-pillar pod here is the Voltmeter gauge I installed--> Just a moment...
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. Front subframe mount?
    By 310toumad in forum Brakes/Suspension/Chassis
    Last Post: 06-13-2016, 01:07 PM
  3. subframe mount interchange
    By 91parkave in forum General Grand Prix Discussion
    Last Post: 04-26-2015, 08:19 PM
  4. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  5. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
