Thread: P1629 and P1673
Results 1 to 10 of 10
  1. #1 P1629 and P1673
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    P1673
    Description
    ENGINE HOT LIGHT CONTROL CIRCUIT
    Output Driver Modules (ODM) are used by PCM to turn on
    current-driven devices needed to control various engine and transaxle
    functions. Each ODM can control up to 7 outputs by supplying ground to
    device PCM is commanding on. ODMs can diagnose each circuit
    individually. If ODM output (ENGINE HOT light indicator driver
    circuit) detects an improper voltage level, DTC will set.
    Symptoms
    You likely won't notice any drivability problems.
    Causes
    An improper voltage level has been detected on ENGINE HOT
    light indicator driver circuit.
    Solutions
    Check for shorts or bad connections in ENGINE HOT light
    control circuit.
    Replace fuse.
    P1629
    Description
    THEFT DETERRENT CRANK SIGNAL MALFUNCTION
    Vehicle operation is disabled if incorrect key or starting
    procedure is used. Vehicle Theft Deterrent (VTD) module enables crank
    circuit to starter and sends a signal to PCM if correct key is being
    used. If proper signal does not reach PCM fuel enable signal circuit,
    PCM will not pulse injectors on, disabling vehicle, even if crank
    circuit is by-passed. Signal should be between 40-60 Hz and is
    measured using DC scale on DVOM.
    Symptoms
    Engine will not run
    Causes
    PCM detects incorrect signal on theft deterrent fuel enable
    circuit.
    Solutions
    Check for faulty connection at TDS module.
    Bypass VATs(92-99 only)
    Replace VTD module.
    Are these codes any thing I should worry about. They came up on my aeroforce the other Day I cleared them and they have not come back on. Now I have had a few really cold days where I have used my Remote start and then when I get in the car and put the key in to drive away the Security light stayed on till I shut the car off and used the key to start it. Now I have started my car many times witht the remote start and only twice has the Security light stayed on.
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: P1629 and P1673
    Naugatuck CT
    And what is the ENGINE HOT LIGHT CONTROL CIRCUIT
  3. #3 Re: P1629 and P1673
    Naugatuck CT
    any one have any info on these??
  4. #4 Re: P1629 and P1673
    You posted the info about them. When was the last time the car started then stalled?
  5. #5 Re: P1629 and P1673
    Aug 2018
    PA
    So how do you fix the p1673 code need help I have this code 99 grand prix gt
  6. #6 Re: P1629 and P1673
    Mar 2014
    Tucson
    Quote Originally Posted by fomas View Post
    When you cycle the key, does the "Engine Hot" or "Overheat" (or whatever the warning light for over temp says) light up during the bulb check?
  7. #7 Re: P1629 and P1673
    Canada
    It sounds like an issue with the after-market remote start. These need to override anti-theft systems since the security chip in the key won't be present when you start the car remotely. I'd be checking the remote start unit. It may be failing or may have a loose connection.
    '01 Grand Prix GTP Special Edition
    Trying to stay pretty close to stock now. Just a few bolt-ons for fun.
    Trying to keep it alive, pretty, and fun.
  8. #8 Re: P1629 and P1673
    Aug 2018
    PA
    Quote Originally Posted by BrandonHall10 View Post
    No everything seems fine runs at the right temp 180 thermostat installed.
    there is no over heat warning light just the gauge.
  9. #9 Re: P1629 and P1673
    Mar 2014
    Tucson
    I think we're talking past each other. I just did some reading on the Google. *IF* I'm understanding the code set criteria correctly, the code has nothing to do with the actual engine temperature.
    It is there to warn you that your "Idiot light" in the instrument cluster is malfunctioning. I assume they have a code just for this because nobody pays attention to the actual temp gauge.
    This is why I asked very specifically if the warning light illuminates during the "bulb check" when you start the car.
  10. #10 Re: P1629 and P1673
    Aug 2018
    PA
    I dont think there is a warning light for over heating. There is a low coolant light check engine light but no over heating light. As far as I can tell they all work none
    are unlimited .
  1. 99 gtp p1629 help
    By dboy187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2012, 03:32 PM
  2. p1629 with newly installed built trans
    By 01 GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-11-2010, 07:17 PM
  3. Please help...P1629
    By jessie9284 in forum General Tech Discussion
    Last Post: 06-12-2009, 04:43 AM
