Thread: Odometer Reading Using OB2 Scanner
Results 1 to 2 of 2
  1. #1 Odometer Reading Using OB2 Scanner
    Georgia
    I am looking for OB2 scanner. Some scanners claim to give odometer readings. I was wondering if anyone has been able to do this or if it is possible on the W body Regals. As you may be aware the odometer light going out is a common problem. It would be helpful to have an OB2 scanner that could display a current odometer reading.
  2. #2 Re: Odometer Reading Using OB2 Scanner
    theres no scanner to do that. the miles are saved no where but on that cluster. so you need to fix it, then you can see the miles. or if you send it out to one of them cluster repair guys, they can download the miles and load them on a new cluster if need be. as some times you just cant fix these.
  1. Scanner not reading KR?
    By CopperGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2019, 12:47 PM
  2. Odometer Fix
    By Felix in forum General Grand Prix Discussion
    Last Post: 02-13-2019, 05:46 PM
  3. odometer reading/DIC
    By rodburner in forum General Tech Discussion
    Last Post: 06-02-2010, 09:15 PM
