Anything special to look for when I tighten this back up, it is loose on one side, leftside from back of car.
In the trunk, I noted the hardware that holds it on is a nut & screw and I note the screw has what looks like a Torx slot in it, does this require a special tool/way to tighten?
I was thinking of pulling it totally off, because there sounds like there are "leaves, pine needles, junk, etc." , stuck in / under it, is it a good idea to pull it off, clean it up and reinstall it , or should I just tighten it?
Also how are the screws attached to the spoiler?"
my concern is knowing it is 21 years old . . . will it fall apart, mainly where the screws attack to spoiler. Is it made of fiberglass or plastic?
Al
