Thread: Problems with my car bogging down?
Results 1 to 18 of 18
  1. #1 Problems with my car bogging down?
    Aug 2008
    Pennsylvania
    well i currently own a 98 gtp supercharged and i have this problem. When i push on the gas from a stopped position my car bogs down and amost stalls than it will go fast. this happens all the time and i need it fixed am afraid of pulling out, out of fast food restraunts and greenlights. anyone know how to fix it?
  2. #2 Re: Problems with my car bogging down?
    TDCRacing
    Guest
    Do you have an ses light on?
  3. #3 Re: Problems with my car bogging down?
    Feb 2008
    to add on to what TDC said, scan it to check for codes and another thing that is easy to do is check your fuel pressure. I had this problem once, it was low pressure and needless to say the FP was bad.
  4. #4 Re: Problems with my car bogging down?
    TDCRacing
    Guest
    I was going to mention fuel pressure. Glad you remembered lol. Also what kind of maintence have you done on the car.
  5. #5 Re: Problems with my car bogging down?
    Aug 2008
    Pennsylvania
    i currently have done nothing and the service engine light has been on for a while ever since i bought it i need to catch up on some of the work... ill check the fuel pressure stuff but i also need to check the fuel filter as well.
  6. #6 Re: Problems with my car bogging down?
    Aug 2008
    Pennsylvania
    is there anything i can do to try to fix it like an ez fix?
  7. #7 Re: Problems with my car bogging down?
    nope, something is wrong or it would run good. feed us more symptoms to figure it out.
  8. #8 Re: Problems with my car bogging down?
    Aug 2008
    Pennsylvania
    okay low rpm it like seems to want to stall out and almost does. it has stalled out once. when i give it gas from a stop or while moving it like all of a sudden drops rpm and almost stalls...then revs up real high all of a sudden because the gas peddle is pushed down.
  9. #9 Re: Problems with my car bogging down?
    so it idles funny, like it is hunting for an idle? you might have a vacuum leak somewhere.
  10. #10 Re: Problems with my car bogging down?
    Outer Space
    x2
    Check all your vac hoses and make sure everything is connected. However, if you dont have a scanner...take it by a local autoparts store and have them tell you the code(s) you are getting.
    02 GTP 13.6 @ 100mph - SOLD
  11. #11 Re: Problems with my car bogging down?
    Aug 2008
    Pennsylvania
    does it cost a lot for someone to run a scan?
  12. #12 Re: Problems with my car bogging down?
  13. #13 Re: Problems with my car bogging down?
    SE Level Member joe deleon's Avatar
    Apr 2009
    grand ledge mi
    say i got a dumb question hoe do i go about putting a pic of my car there where the x is at sorry but could i get some help im very new at this i just joined
  14. #14 Re: Problems with my car bogging down?
    Apr 2009
    grand ledge mi
    opps how was the word im looking for
  15. #15 Re: Problems with my car bogging down?
  16. #16 Re: Problems with my car bogging down?
    Aug 2008
    Pennsylvania
    update: i got the scan and it says the man. absolute pressure/baro or maf (mass air flow)/ vaf (vane air flow) sencor could be bad, vaccume hose cracked, off, or cracked/ map/barometer is defective
    throttle body intake tube loose, off, or cracked
  17. #17 Re: Problems with my car bogging down?
  18. #18 Re: Problems with my car bogging down?
    Aug 2008
    Pennsylvania
    update: found a hose corroded in half by the battery fixed it and now it runs like new =D
  1. Bogging out problem???
    By NvMySi in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-08-2010, 12:17 PM
  2. A/c Problems
    By TripleZero in forum General Tech Discussion
    Last Post: 08-12-2010, 10:57 AM
  3. NEW GUY NEW Problems!?
    By 06GPNA3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2009, 11:43 PM
  4. some problems
    By EmEaston24 in forum General Tech Discussion
    Last Post: 09-23-2008, 06:28 PM
  5. Many problems/ Please help
    By Vurelis in forum General Tech Discussion
    Last Post: 06-15-2008, 03:45 PM
