I tried to post this weeks ago, hopefully someone will find use of it still- When I got mine and installed them, they were brighter when they should have been on low beam than they were when they should have been on high beam. I recalled reading with other vehicles that sometimes led bulbs could be wired "backwards", so I did a little experimenting. I had an extra headlight jumper harness, so I figured out what was the high v/s low beam pin and swapped them, plugged it in, and tried again. Lo and behold, appropriate brightness and function with no indicator weirdness! I re- pinned the harness on the other side, and put everything back together, and a month or so in, no issues at all. If someone else wants to do this, all you have to do is pop out the outermost pins on the 9007 connector and switch sides in the socket. I can only assume this isn't necessary with all of the ZZP led's, and is likely a QC issue with whoever they have manufacture the bulbs.
