even if the AC isnt pumping cold air, wouldnt the fans kick on with the AC on?
Negative ghostrider. If the compressor doesn't activate due to low pressure switch not having enough reading, then the fans don't come on when you press the AC button, which essentially is useless if the AC doesn't have pressure.
