Thread: Lower temp engine temp sensor needed.
Results 1 to 16 of 16
  1. #1 Re: Lower temp engine temp sensor needed.
    I don't want to correct you like this but I am going too.
    240º is not anywhere close to the fan turn on temps. If we want to get technical with real data the values are 212º low speed and 226º high speed. These are based on the 97-03 body style, the 2004-2008 cars are almost the exact same, within a few degrees of each other.
    As said, hook up a scan tool and watch what that says. The cluster may be reading way different than the computer. If that is the case I'd break down a purchase a new OEM temp sensor, install a new thremostat at the same time and bleed the cooling system. Then see where you stand with the problem.
  2. #2 Re: Lower temp engine temp sensor needed.
    SE Level Member Wakingcrow's Avatar
    Mar 2017
    Florida
    Well I'm not going to redo the entire cooling system because I already do that and have been replacing the tstat and coolant every year so those aren't the problem. I replaced the temp sensor once as well but that was a couple years ago. So you're saying the OBD scanner will read a temp different than what the temp sensor tells it? If so then where does it get this alternate temp?
    Thanks.
  1. Temp gauge problem after coolant temp sensor change.
    By Beast388 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2015, 08:00 PM
  2. WTB Engine Temp sensor
    By chris99gtp in forum Wanted To Buy - Parts
    Last Post: 09-02-2015, 09:08 PM
  3. engine coolant temp sensor
    By Dee23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2015, 06:28 PM
  4. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  5. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
