Thread: Car running LEAN right after it was running fine for what reason?
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 98
  1. #1 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by SgtMarshal View Post
    older hp tuner software will open the bins. something like 2.2, pretty sure it's in bill's dropbox
    So I open bin, save it as .hpt, then I can edit it with current hpt and flash to my car? I'm more worried about bricking my pcm or something. Or would I have to buy more credits to flash what was once a bin?
    Top Swapped 01 Imp
  2. #2 Re: Car running LEAN right after it was running fine for what reason?
    Kemmerer, Wyoming
    I would stick with the older software if it's an option, do you have the newer version of hp tuner, the one that connects via bluetooth?
  3. #3 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Yeah I have MPVI2 standard.
    Top Swapped 01 Imp
  4. #4 Re: Car running LEAN right after it was running fine for what reason?
    Kemmerer, Wyoming
    Quote Originally Posted by bandook View Post
    is it a cable or does it use bluetooth to connect?
  5. #5 Re: Car running LEAN right after it was running fine for what reason?
    ok then, so take that bin copy it, make a edited one in TT, then dl hpt 2.2 open and save it. it will save as a .hpt, then you can flash it.
  6. #6 Re: Car running LEAN right after it was running fine for what reason?
    Dropbox - VCMSuite-2_2_0.msi - Simplify your life should get you to a old 2.2 hpt install
    or this is the whole hpt folder to pick from. Dropbox - HPT software - Simplify your life
  7. #7 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Thanks, Scotty. I have bills DB saved. I tried installing, but it requires Net Framework 1.1. Might be a pita to install it on Win10, but i'll figure it out.
    Top Swapped 01 Imp
  8. #8 Re: Car running LEAN right after it was running fine for what reason?
    its in the folder there, just install it, it wont hurt anything. or you can google it and get it for free off the microsoft site.
  9. #9 Re: Car running LEAN right after it was running fine for what reason?
    the latest unit may not run the older vs.
  10. #10 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Wouldn't it be backwards compatible? I was thinking i should be able to just open the .bin on 2.2, save as .hpt, then open in latest version, make changes, save, flash to car.
    Top Swapped 01 Imp
  11. #11 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Cable. I haven't even looked at the bluetooth feature. Thought that was just for the track app. I just opened it, plugged it in and started tuning.
    Scotty, I'll figure it out. But 2.2 is giving Win 10 issues. I got the 2.22 installed but it crashes and won't save the bin.
    Top Swapped 01 Imp
  12. #12 Re: Car running LEAN right after it was running fine for what reason?
    might have to do one of them deals where you tell it to run in XP or win 7.
  13. #13 Re: Car running LEAN right after it was running fine for what reason?
    you might have to flash witht he old vs. i had to upgrade my editor to see your hpt file. and the one im on is pretty new, so it might not even open it.
  14. #14 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Back to my original issue, who's running a HAI?
    Top Swapped 01 Imp
  15. #15 Re: Car running LEAN right after it was running fine for what reason?
    i do.
    Car running LEAN right after it was running fine for what reason? Attached Images
  16. #16 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    BTW, you need to paint them bones. Yellow?
    Top Swapped 01 Imp
  17. #17 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    What's that copper tubing under your tensioner bracket?
    Top Swapped 01 Imp
  18. #18 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Yeah but you got meth. Cheater! Honestly though, I think I'm good for one more mod. It's between rockers or meth. I almost had a set of used 1.9's but the dude backed out.
    What are your normal IAT's on a warm day?
    Top Swapped 01 Imp
  19. #19 Re: Car running LEAN right after it was running fine for what reason?
    thats my fuel rail. its a custom cut chop rebuild of a stock rail.
    my ait's are hot if sitting, but dont really affect my trims. im like -5 or lower all the time. and they are still the same after the n* and new maf with ait built into it.
  20. #20 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    That's awesome, forgot all about the diy fuel rails. I need to figure out a better way to attach the stock lines to the l67 fuel rail. They don't leak puddles, but I can always smell corn vapor from the slip on connection. Wiggle them and they leak.
    Do you still have a hood liner? I'm thinking of ways to remove engine heat. That and wrap headers. Only my crossover is wrapped.
    Looking at this wrap.
    Top Swapped 01 Imp
  1. Running lean?
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2012, 01:05 PM
  2. Running lean
    By camarofan1974 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 03:25 PM
  3. running lean?
    By Brennan7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:07 AM
  4. Running Lean
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:06 AM
  5. Car Running Rough then Fine
    By Smitty in forum General Tech Discussion
    Last Post: 09-22-2009, 03:39 PM
