Thread: Car running LEAN right after it was running fine for what reason?
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 98
  1. #21 Re: Car running LEAN right after it was running fine for what reason?
    May 2008
    Schuyler, NE
    You should be able to find 1 bar settings if you download a stock tune from hpt's tune repository.
  2. Likes bandook liked this post
  3. #22 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Didn't really make a difference. Car feels the same. I assumed it was only limiting the pcm from seeing boost According to the logs it's the same from max vacuum to atmosphere. I'll have to hit the Yard and get another 1 bar. I'm not paying 60 bucks for a new map for this test. I never had luck buying aftermarket sensors from autoparts stores anyways.
    Top Swapped 01 Imp
  4. #23 Re: Car running LEAN right after it was running fine for what reason?
    May 2008
    Schuyler, NE
    If you want, I probably have one I can mail you. If you can wait a few days.
  5. Likes bandook liked this post
  6. #24 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Thanks for reminding me! I had thought a few days ago about just setting everything back to stock. My first tune was made for me by a guy here. He sent me a tune before I started the engine, i just wanted a base to learn. I don't have that tune any more, or my stock file. I lost all my tunes from 4 years ago.
    So I set all the tables, even spark, back to stock except for what I needed to tune MAF. Car started nice and the afr error didn't jump around. It did keep rising all the way to 180 degrees, though. But at least I have a stable platform to start experimenting now, thanks to you.
    Wideband read 16.1 max when warmed.
    Top Swapped 01 Imp
  7. #25 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Also, my idle is closest to matching commanded than its ever been. 700 commanded, 725ish actual.
    I decreased AFR : Fuel-Open Loop/Base-OL AFR : to match the scan. That should have been the first thing I did before trying to drive and log. I wonder if the stock VE table played a part. Like you said, it seems to be a mystery what they do on some cars.
    Top Swapped 01 Imp
  8. #26 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Still getting lean the longer I run the car. My untrained eyes can't spot anything in the tune. I'm guessing...either a sensor is losing resistance as it gets heat soaked, or the injectors. The ECT is stable, but the wideband is seeing lean creep in the longer I drive. Wish I had a fuel pressure gauge I could use when driving. My harbor freight gauge show 63psi at idle. Fuel pump is fairly new aem e85 pump.
    Top Swapped 01 Imp
  9. #27 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Another thing I am thinking. Is it Possible that the PCM is getting heatsoaked and causing issues? Stock location is in the airbox, where hot air is being pulled away. Since my box was removed, it's just sitting vertical where it was on a bracket i made. I mean, it's a computer, computers don't like too much heat, and the factory put it in the flow of cooler air. I'm gonna rig up some cooler air ducting and test.
    Top Swapped 01 Imp
  10. #28 Re: Car running LEAN right after it was running fine for what reason?
    No. My computer sat for 4 years on the frame where the air box used to be. Never once ran into any problems.
  11. #29 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Well I'm stumped then. If anyone wants to look, here's a new log. I left my parents home, 20 minute drive. At first I was happy, error was small. By the time I got home it was running lean. I had thought maybe my wideband was failing, giving false numbers, but i can definitely feel and hear the leanness.
    I have 42lb injectors I could swap back in. Don't think they will be enough for e85, but enough to test for this issue.
    Scan
    Tune
    Top Swapped 01 Imp
  12. #30 Re: Car running LEAN right after it was running fine for what reason?
    Kemmerer, Wyoming
    your fuel trims are 0 across the board? did you hit relearn fuel trims on the scanner? or reset fuel trims
  13. #31 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by SgtMarshal View Post
    I'm doing an O/L MAF tune. PE set to zero, 14.7 commanded, closed loop disabled by setting enable to 284°. Commanded still bounces around until I'm at around 24% throttle. Shouldn't make a difference I think, because I'm tuning wideband/commanded error.
    Top Swapped 01 Imp
  14. #32 Re: Car running LEAN right after it was running fine for what reason?
    Kemmerer, Wyoming
    that doesn't make any sense to me.
  15. #33 Re: Car running LEAN right after it was running fine for what reason?
    i think your still trying to ve tune and dont know it. cause thats not how to tune a maf. thats how you tune VE. wb err means about nothing for maf tuning.
  16. #34 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    This is the guide I am trying to follow. Makes the most sense to me.
    Top Swapped 01 Imp
  17. #35 Re: Car running LEAN right after it was running fine for what reason?
    Kemmerer, Wyoming
    that seems too unconventional for me, and apparently doesn't work well if something is off. I recommend going back to using your maf sensor and o2 sensor.
  18. #36 Re: Car running LEAN right after it was running fine for what reason?
    May 2008
    Schuyler, NE
    He is using the MAF. This method works really well and is a lot faster than using the stock narrowband. The wideband is just slightly less accurate at lamba than the narrowband is.
  19. #37 Re: Car running LEAN right after it was running fine for what reason?
    May 2008
    Schuyler, NE
    Looking at the scan, I am noticing your narrowband o2 is doing some weird stuff. I would try unplugging it and see if anything changes.
  20. #38 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    He is using the MAF. This method works really well and is a lot faster than using the stock narrowband. ..
    Works a lot faster, lol! I've probably scanned and adjusted maf 30 times now. I know what your saying though. It most definitely should be a quick process. Russ, the guy who made the write-up, said it takes him minutes. 2-3 sub 7000hz tunes, and a wot tune.
    I'll unplug my o2 tonight and see what happens. I considered it because that was his preferred method, but I'm definitely in open loop, no trims. So not sure why it would matter. Then again, I am always suspicious of the hidden tables in the PCM. Might still be some weird corrections happening with o2?
    Top Swapped 01 Imp
  21. #39 Re: Car running LEAN right after it was running fine for what reason?
    May 2008
    Schuyler, NE
    Yeah, it should be in open loop, but it looks to be doing weird things. My suspicion is that it could be causing issues.
  22. #40 Re: Car running LEAN right after it was running fine for what reason?
    Apr 2015
    Columbus, OH
    @GTPpower....
    upload
    My O2 harness. I think we found our issue, lol. Gonna separate the wires, leave it unplugged and go for a drive. Would definitely explain why it gets leanner the longer it runs. Was sitting right on top of my header.
    Top Swapped 01 Imp
  1. Running lean?
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2012, 01:05 PM
  2. Running lean
    By camarofan1974 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 03:25 PM
  3. running lean?
    By Brennan7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:07 AM
  4. Running Lean
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:06 AM
  5. Car Running Rough then Fine
    By Smitty in forum General Tech Discussion
    Last Post: 09-22-2009, 03:39 PM
