Thread: Question regarding code P0741
Results 1 to 8 of 8
  1. #1 Question regarding code P0741
    Apr 2011
    North Los Angeles
    Hello all, I am having transmission issues and am getting code P0741.
    Some of my symptoms include -
    Hesitation accelerating (as if there's a blockage in the muffler) then a kick and a sudden burst of acceleration
    At high speeds the rpm drops to 1-1.5k and when accelerating at high speeds the rpm has to "catch up" with where it should be around 3000 rpm @ 80mph and you feel a slight jolt.
    Over all acceleration issues then the engine catching up,rpms going to 4-5k and the car just slowly accelerates etc.
    I know this code involves the torque convertor, can it potentially be an easy fix, it mentions a circuit. Or is this a big job that'll require tranmssion removal? I need to get this out of the way to pass smog, if it is a big fix issue, can the code be silenced or removed? Thanks everyone.
  2. #2 Re: Question regarding code P0741
    Sorry.. I'm too lazy to look up 741.
  3. #3 Re: Question regarding code P0741
    Apr 2011
    North Los Angeles
    I did a search before posting, I noticed you mentioned having a link to your repair tutorial but could not locate. Also not exactly sure what to do or which component to replace.
  4. #4 Re: Question regarding code P0741
    Mar 2014
    Tucson
    My anecdotal experience:
    Brother in law had similar symptoms and trouble code, along with a couple other codes related to stuck solenoids. Long story short; Torque convertor clutch shredded sending clutch material through the entire trans. The solenoids were stuck due to grit in the bores. Only fix was a full rebuild.
    Drop the pan to see what the fluid and magnet look like.
  5. #5 Re: Question regarding code P0741
    Apr 2011
    North Los Angeles
    I recently did a flush and there was no shredded metal or abnormal debris.
  6. #6 Re: Question regarding code P0741
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    The mechanical flush probably did the transmission in. In the 4T65E world, it's heavily recommended never to flush.
    Torque converter lockup issues may relate to the TCC solenoid, which requires the side cover off. You'd have the trans almost out by then doing it properly.
    Can do solenoids, hope the harness clips don't break and pray the issues are gone 1st run, or start saving up for a rebuild. Either are not attractive options, imho.
  7. #7 Re: Question regarding code P0741
    Apr 2011
    North Los Angeles
    Quote Originally Posted by SaukRapids View Post
    The issue was there before the flush, trans oil smelled burnt so I thought it would help.
  8. #8 Re: Question regarding code P0741
    Apr 2011
    North Los Angeles
    Seems like all the links on the older sight have disappeared? Lots of great info and tutorials there. I remember there was that epic Billboost trans and engine swap that really helped me years ago. I am still having struggles with the code and am considering just swapping out the entire trans for a used one. Does anyone have a link for a swap tutorial on this newer site? Would this route be easier than trying to fix the torque converter?
  1. Cat code question.
    By nos4blood70 in forum PCM Tuning
    Last Post: 05-11-2013, 06:21 PM
  2. RPO code question
    By 98L36 in forum General Tech Discussion
    Last Post: 08-09-2011, 09:37 AM
  3. o2-cat code question.
    By gtpinsc in forum General Tech Discussion
    Last Post: 03-31-2011, 09:15 AM
  4. DTCS P0700 and P0741
    By zebulun in forum 5.3L V8 (LS4)
    Last Post: 08-27-2010, 05:02 AM
  5. Have a question about this code
    By tyv193 in forum Off Topic Discussion
    Last Post: 08-09-2010, 11:08 AM
