Thread: ignition woes
Results 1 to 11 of 11
  1. #1 ignition woes
    Apr 2011
    North Los Angeles
    Hello all, having strange ignition problems. I turn the key and I get a click and no crank, everything worked perfectly until I tried an hour ago. I hooked a jumper in case it was the battery but nothing. I feel like it's an ignition problem. All lights turn on gauges react but no crank. My key recently got stuck in the ignition and I had to wiggle it out aggressively, I've heard this could be it. Anyway to bypass the ignition system to verify or eliminate this? Almost positive it's not the anything in the starting system.
  2. #2 Re: ignition woes
    sounds like a dead starter. they click in the dash when you turn the key and no crank.
  3. #3 Re: ignition woes
    Apr 2011
    North Los Angeles
    It is possible but I had zero symptoms before cranking it just now it started great with no hiccups before, but I do agree, based off my description it does sound like a dead starter.
  4. #4 Re: ignition woes
    mine just crapped out. you can try hitting the fat part of the body with a hammer while someone holds the key to crank. some times they come back to life, if it does after a beating its bad for sure.
  5. #5 Re: ignition woes
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by steelholder View Post
    as scotty said, they can sometimes not show any symptoms and sometimes they are but we dont notice. i had a ford taurus that had a symptom that would show would be a real quick hesitation when turning the key. for a split second the starter would engage but not turn. if a person wasnt paying attenention they wouldnt notice until it just wouldnt start the car.
  6. #6 Re: ignition woes
    Apr 2011
    North Los Angeles
    Thanks Scotty and Tom, today I put it neutral to push the car onto a sturdier surface to jack it up. I tried the key for hell of it and it started up fine. I wonder if pushing it rotated something in the starter or elsewhere. I drove it around turned off and on a bunch of times and it's perfect again. I suspect it will crap out in a bad situation in the near future and have reliability anxiety now..sigh.
  7. #7 Re: ignition woes
    Seems more like a wiring issue. Go over the power and ground cables and clean them up.
  8. #8 Re: ignition woes
    Nothing in the ignition system rotates when you push the car in neutral. You can rule that out.
  9. #9 Re: ignition woes
    Apr 2014
    commerce twp,mi
    now its sounding like that. could even be internal in the starter but clean up them cables and see what happens.
  10. #10 Re: ignition woes
    Mar 2018
    NY
    I thought starter till he stated key getting stuck in ignition. That's a sign of low voltage. Make sure your battery terminals are clean and securely connected.
  11. #11 Re: ignition woes
    May 2019
    MS
    Any follow up on this? Did the issue return or figure out what was wrong with it? I'm having a similar issue.
  1. More DHP woes
    By BoostedPontiac in forum PCM Tuning
    Last Post: 02-22-2016, 02:34 PM
  2. LIM Woes
    By EJOUIE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2015, 10:06 PM
  3. misfire woes
    By Silversurfer Gio in forum General Tech Discussion
    Last Post: 06-07-2014, 10:21 PM
  4. MAF sensor woes
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 01-09-2013, 01:38 PM
  5. security woes
    By UR LOSN in forum General Tech Discussion
    Last Post: 10-28-2008, 09:17 AM
