Thread: LIM Woes
Results 1 to 20 of 32
  1. #1 LIM Woes
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    LIM gasket job.
    Reattaching the new LIM as the old one was toast. Very brittle in spots and had a hole in it.
    Bolt #6 is not tightening. Its just free spinning. Manifold alignment is perfect as I can see way down the bolt hole.
    Can i skip it and come back when the LIM is lower and hopefully it catches?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: LIM Woes
    thats what id do, when the lim is pulled further down prey it catches threads.
  3. #3 Re: LIM Woes
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Did your original LIM have pits where the coolant passage ended? And how many miles when you did the gasket change?
  4. #4 Re: LIM Woes
    the blocked side of the lim on my 98 gs looked good and pitted. had around 220,000 on it. it sealed just fine.
    the l36 lim i have looked damn good, but its 1/2 the miles @ 109,000.
  5. #5 Re: LIM Woes
    Apr 2015
    So you don't think mine will be pitted? Or if it is, it won't be that much. I've got 124xxx miles right now.
  6. #6 Re: LIM Woes
    Newnan, GA
    Anybody know where I can order new LIM bolts? I lost one by the crossover and cant find it. Kinda thinking it may be best to replace them all though.
  7. #7 Re: LIM Woes
    take one to the hardware store and match it up. id re use the bolts. why not?
  8. #8 Re: LIM Woes
    Newnan, GA
    You wouldn't happen to have one around and give proper numbets on would ya? Mine is missing a few threads and doesn't match up with whats at the hardware store.
    Thanks for the help. I really appreciate it.
  9. #9 Re: LIM Woes
    Newnan, GA
    Never mind. Apparently they don't have to be exact replacements. I got ones that fit. Crisis averted.
  10. #10 Re: LIM Woes
    if need be i do have a set of used lim bolts.
  11. #11 Re: LIM Woes
    Newnan, GA
    Thanks for the offer Scotty, but I think I found a solution.
    Also found out that my pintle caps on my injectors are disintegrating due to age. These are not generally available at the auto parts stores or am I not searching correctly?
  12. #12 Re: LIM Woes
    as long as the o ring will seat on there when pushed in its ok if the bottom is cracked or missing.
    iirc its a rebuild kit that has new bottoms and the little filter inside the injector.
  13. #13 Re: LIM Woes
    Newnan, GA
    One was completely gone. Others had cracks and brittle around the tip. Somehow they are putting up a fight to be removed in one piece. Seems to be faster to let them break into chunks and then watch them fall off.
    I found some universal caps online. Going to see if those work as I already have the o rings for top and bottom.
  14. #14 Re: LIM Woes
    Newnan, GA
    Still waiting on the caps, but I've put on a few more components. I've got the throttle body on and am tightening down the alternator. However I seem to have an extra nut. It's just like the one that goes on the positive terminal on the alternator. Its a 97 so the setup is a little different, but I do have the 3 bolts finger tight.
  15. #15 Re: LIM Woes
    it go on the end of the long bolt that goes through the alt bracket and alt? its the only bolt that dont go into the block for the alt bracket.
  16. #16 Re: LIM Woes
    the high part to the right of the alt bracket is where im talking about.
  17. #17 Re: LIM Woes
    Newnan, GA
    The bolt doesn't stick out near the plenum. Also there is not enough space for the nut to fit. However there is a bit of space between the support bracket and the alternator itself. The support is a bit concave and a nut would fit in there. I just don't see why though, which is why I wasn't sure that was it's proper place.
  18. #18 Re: LIM Woes
    pic and size of the nut. if any one will know its bill lol
    theres no nuts in the install of the alt or bracket, inless it came off the stud there for a support bar/bracket that some cars have.
  19. #19 Re: LIM Woes
    Newnan, GA
    I think I just figured it out. Silly me.
    From in moving out: Alt, stud, bracket, nut.
    NOT: alt, bracket, stud. (nut?)
  20. #20 Re: LIM Woes
    Newnan, GA
    bingo.
  1. misfire woes
    By Silversurfer Gio in forum General Tech Discussion
    Last Post: 06-07-2014, 10:21 PM
  2. Window Woes
    By MrPhotographer06 in forum General Tech Discussion
    Last Post: 02-18-2011, 12:32 AM
  3. computer woes
    By Biohazed in forum Off Topic Discussion
    Last Post: 07-13-2010, 04:59 PM
  4. security woes
    By UR LOSN in forum General Tech Discussion
    Last Post: 10-28-2008, 09:17 AM
  5. Subscription woes
    By Preotic in forum Off Topic Discussion
    Last Post: 02-01-2008, 07:28 AM
