Thread: Coolant leak behind water pump
Results 1 to 7 of 7
raythecaddie Coolant leak behind water pump 03-31-2019, 09:57 PM
Fivefingerdeathpunch Re: Coolant leak behind water... 03-31-2019, 10:03 PM
raythecaddie Re: Coolant leak behind water... 04-01-2019, 08:08 AM
Fivefingerdeathpunch Re: Coolant leak behind water... 04-01-2019, 07:09 PM
raythecaddie Re: Coolant leak behind water... 04-02-2019, 07:34 PM
Scottydoggs Re: Coolant leak behind water... 04-01-2019, 09:32 AM
Fivefingerdeathpunch Re: Coolant leak behind water... 04-02-2019, 08:17 PM
  1. #1 Coolant leak behind water pump
    Nov 2018
    Canada
    I have a 2006 grand prix and it seems that I have a coolant leak in behind the water pump, how can that be and what part is behind the water pump
  2. #2 Re: Coolant leak behind water pump
    The front cover bolts to the block with a gasket. It can leak coolant between the block and cover.
    That is a possible leak if the water pump is okay. Or the other leak is the coolant elbow above the water pump leaking down.
  3. #3 Re: Coolant leak behind water pump
    Nov 2018
    Canada
    Thanks for the reply, does the water pump bolt directly onto the block or is there a part between the pump and the block. The pump was recently changed by a mechanic and he said the part behind the water pump is also leaking and he would fix it for $700, but I called bs on that. I always thought the pump bolts directly to the block.
  4. #4 Re: Coolant leak behind water pump
    Quote Originally Posted by raythecaddie View Post
    The pump bolts to the front cover, which is bolted to the engine block.
  5. #5 Re: Coolant leak behind water pump
    Nov 2018
    Canada
    From further research I guess that would be the timing chain cover that the water pump bolts to. I read somewhere that you could remove the water pump and the timing chain cover all in one piece by removing only the 4 larger water pump bolts that go right through to the cover...your thoughts on this or do you know of any tricks or tips to make the job easier.
  6. #6 Re: Coolant leak behind water pump
    if the leak is from under the water pump snout and pulley, its the pump leaking, most common leak. you can grab the w/p pulley with two hands, push and pull with each hand back and fourth, it you got play the pump is bad for sure.
    if you got a mirror and a flash light, you can see under the pulley to the snout and see the wet weep hole under there.
  7. #7 Re: Coolant leak behind water pump
    You still have to take the balancer pulley off with a special puller, then remove the front timing cover. And yes, just for those long bolts is all you need to take off plus the rest of the timing cover bolts.
  1. oil leak, seems to be above water pump but cant tell
    By basimpo in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-06-2015, 05:59 PM
  2. Coolant/Water Leak? Please help!
    By bm2112 in forum General Tech Discussion
    Last Post: 05-17-2012, 05:09 PM
  3. water pump or coolant elbows?
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 12-10-2011, 03:20 AM
  4. Water pump leak, or not?
    By 04silverprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2011, 11:25 PM
  5. water pump housing leak??
    By 16MustangVet in forum General Tech Discussion
    Last Post: 02-08-2010, 12:06 PM
