if the leak is from under the water pump snout and pulley, its the pump leaking, most common leak. you can grab the w/p pulley with two hands, push and pull with each hand back and fourth, it you got play the pump is bad for sure.
if you got a mirror and a flash light, you can see under the pulley to the snout and see the wet weep hole under there.
